| Steve73 |
Jul 18 2011, 02:12 AM
Photographer/Shade Tree Mechanic ![]() ![]() Group: Members Posts: 125 Joined: 2-July 11 From: Nashville Member No.: 13,269 Region Association: South East States |
I'm trying to bring a dead 914 back to life. I have done the usual prep work and have hooked up the electrical system. The car turns over strongly but there is no spark! No spark at the plugs, no spark at the coil. I have switched the coil out with one I had laying around but i'm not getting any better results. Could it be the voltage regulator located in the box where the fuel injected controls are? (mine has been converted to dual carbs BTW).
What should I try next? Thanks in advance! |
| Cap'n Krusty |
Sep 20 2011, 05:05 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
And where is he going to find bushings? The wrong bushings are apt to be worse than the old ones. Bosch never sold them for VW/Porsche applications. Besides, that, bushing wear is an overplayed issue, and rarely causes a serious problem. Worn out breaker plates (not in the 009, of course) are of much greater concern, especially their ground strap. Check the following parts, in order. The points. Are they opening and closing and do they have the proper gap? Using an ohm meter attached to the point wire and the distributor body, open and close the points and watch the meter. Ohms, infinity, ohms, infinity, and so on. The timing. Is it close, and are you on the right cylinder? The condenser. Is it shorted out against the body? They rarely fail. I'll bet I haven't changed an average of one a year over the nearly 40 years I've been working on cars professionally. Is the point/condenser wire plugged in to the (-) side of the coil (#1), along with the tach wire? The power wire to the coil. Is it plugged into the (+) side of the coil (#15)? Coil wire to the distributor cap good? You sure? The rotor. Continuity from center to tip? Does it turn when you crank the engine? The cap. No cracks, carbon tracks, obvious nastiness, and a good button in the center?Fix anything that's not right as you encounter it. Report back.
The Cap'n Report back |
Steve73 No spark! Jul 18 2011, 02:12 AM
corsepervita How is the voltage up to the coil? The grounding?
... Jul 18 2011, 03:52 AM
vsg914 Condensor Jul 18 2011, 05:01 AM
Prospectfarms Unlikely you have two bad coils. A good coil may n... Jul 18 2011, 07:34 AM
Steve73
Unlikely you have two bad coils. A good coil may ... Jul 18 2011, 10:39 AM
Drums66 ......Look at the grounding points, do them
coil ?... Jul 18 2011, 11:12 AM
codemasterlax i have the same problem with mine not getting spar... Sep 20 2011, 02:25 PM
Prospectfarms
i have the same problem with mine not getting spa... Sep 20 2011, 02:36 PM
underthetire
i have the same problem with mine not getting spa... Sep 20 2011, 02:44 PM
codemasterlax i do have in a bosch coil but wht bushings Sep 20 2011, 02:47 PM
underthetire Grab the rotor and try and wiggle it side to side.... Sep 20 2011, 02:51 PM
codemasterlax it does wiggle a lot but could tht also be because... Sep 20 2011, 02:56 PM
underthetire
it does wiggle a lot but could tht also be becaus... Sep 20 2011, 03:06 PM
codemasterlax ok what part exactly do i need to replace on the d... Sep 20 2011, 03:11 PM
underthetire You would need to disassemble the dizzy, Press the... Sep 20 2011, 03:53 PM
Prospectfarms
And where is he going to find bushings? The wron... Sep 20 2011, 07:01 PM
underthetire
And where is he going to find bushings? The wron... Sep 20 2011, 07:20 PM
Prospectfarms
And where is he going to find bushings? The wro... Sep 20 2011, 09:12 PM
Steve73 Prospect Farms Thanks for asking about my 914.
I ... Sep 21 2011, 01:56 AM
underthetire
I... Sep 21 2011, 08:59 AM
Steve73
[quote name='Steve73' post='1542174' date='Sep 21... Sep 25 2011, 09:53 PM
Steve73 I've got the engine running pretty well with t... Oct 7 2011, 03:23 PM
vsg914 44 is the low side of the dwell. 47 would be bette... Oct 7 2011, 04:13 PM
Prospectfarms Per: Pelican: timing with Carbs.
Set timing at 320... Oct 7 2011, 10:25 PM
Steve73 Thanks everyone but I still need some advice about... Oct 7 2011, 11:48 PM
Prospectfarms
Thanks everyone but I still need some advice abou... Oct 8 2011, 09:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 12:51 PM |
