> Clutch Cable, Broke over the white roller ?
jim_hoyland
post Sep 20 2011, 02:44 PM
Get that VIN ?
Any particular reason the clutch cable would unravel at the top of the roller ? Should the roller spin freely when reasembled ?
A few pics of what I'm looking at... (IMG:style_emoticons/default/smile.gif)
1970 Neun vierzehn
post Sep 20 2011, 07:41 PM
I bought my 914 in 1975. Within 2 years after that, my clutch cable failed at the cable pulley. I thought that keeping it clean would prevent a build-up of grime, which would abrade the cable and pulley. After that failure, with a new cable in place, I coated the pulley, cable and mounting point with a liberal application of white grease. Every year or two, I clean the old grease off, run a few pipe cleaners around the pulley groove and slather the assembly with another coat of white grease. I have not had a cable failure since 1977.
Paul
jim_hoyland   Clutch Cable   Sep 20 2011, 02:44 PM
underthetire   Cause thats where it makes a U-turn. Yes, the roll...   Sep 20 2011, 02:48 PM
type47fan   Cause thats where it makes a U-turn. Yes, the rol...   Sep 20 2011, 06:25 PM
kg6dxn   Yep, that's where the most load is on the cabl...   Sep 20 2011, 03:57 PM
Drums66   .....Defective cable(clutch) & yes it should r...   Sep 20 2011, 03:58 PM
1970 Neun vierzehn   I bought my 914 in 1975. Within 2 years after that...   Sep 20 2011, 07:41 PM
jim_hoyland   I bought my 914 in 1975. Within 2 years after tha...   Sep 20 2011, 08:40 PM
PRS914-6   You can go to Fatzer Cable and download Guidelines...   Sep 20 2011, 07:53 PM
euro911   Jim - Unless you set it aside before snapping the ...   Sep 20 2011, 10:51 PM
jim_hoyland   Jim - Unless you set it aside before snapping the...   Sep 21 2011, 08:11 AM
Elliot Cannon   Jim - Unless you set it aside before snapping th...   Sep 21 2011, 08:49 PM
rohar   Yup, good diagnosis and suggestions by all. I...   Sep 21 2011, 08:19 AM
ChrisNPDrider   I just replaced my clutch cable after seeing the f...   Sep 21 2011, 01:58 PM
jim_hoyland   I just replaced my clutch cable after seeing the ...   Sep 21 2011, 05:40 PM
jcd914   Seems like a boot could really protect this area-...   Sep 22 2011, 02:14 AM
jim_hoyland   Seems like a boot could really protect this area...   Sep 22 2011, 08:28 AM
jcd914   I just replaced my clutch cable after seeing the...   Sep 23 2011, 07:02 PM
ChrisNPDrider   Did you find foreign material in the wire too ? ...   Sep 22 2011, 01:36 PM
1970 Neun vierzehn   Did you find foreign material in the wire too ? ...   Sep 22 2011, 08:15 PM
jim_hoyland   No, I was thinking of a boot that would cover th...   Sep 23 2011, 07:17 AM
euro911   In addition to a boot (bellows) being a good idea,...   Sep 23 2011, 01:08 PM
jim_hoyland   :birthday3: In addition to a boot (bellows) being...   Sep 23 2011, 06:31 PM
914Mike   In addition to a boot (bellows) being a good idea...   Dec 17 2011, 03:08 AM
rgalla9146   In addition to a boot (bellows) being a good idea...   Dec 17 2011, 06:59 AM
Dave_Darling   Euro, that is a stock part. Part number 914 423 2...   Sep 23 2011, 06:44 PM
jim_hoyland   Euro, that is a stock part. Part number 914 423 ...   Sep 24 2011, 09:23 AM
Drums66   Euro, that is a stock part. Part number 914 423...   Sep 24 2011, 11:36 AM
euro911   Euro, that is a stock part. Part number 914 423 2...   Sep 25 2011, 11:28 AM
euro911   [quote name='Dave_Darling' post='1543412' date='Se...   Dec 16 2011, 02:14 PM
jim_hoyland   [quote name='Dave_Darling' post='1543412' date='S...   Dec 16 2011, 04:31 PM
- Lo-Fi Version Time is now: 17th November 2026 - 08:54 AM
