How to remove jugs from heads? |
tornik550 |
Sep 24 2011, 09:12 AM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have never had this issue before. I have new AMC heads and new EMW 96mm clyinders. I assembled the longblock to check valve train geometry. I need to send my heads off to get the valve guide bosses cut however I cannot remove the jugs from the heads. I do not want to break any fins so I haven't tried much other than muscle.
Any ideas? Attached image(s) |
TheCabinetmaker |
Sep 24 2011, 09:26 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Uh, something is seriously wrong. I think amc heads are 1.7 bus castings that were modified for the 2 litre. You might have to open up the registers for the 96mm cylinders to fit into.Might try air pressure thru the plug holes to pop them loose.
tornik550 |
Sep 24 2011, 09:45 AM
Uh, something is seriously wrong. I think amc heads are 1.7 bus castings that were modified for the 2 litre. You might have to open up the registers for the 96mm cylinders to fit into.Might try air pressure thru the plug holes to pop them loose. These heads are setup for 96mm jugs. The strange thing is that prior to putting the engine together, I put one of the jugs in the head to make sure it fit properly. There was a very precise fit, I did not difficulty putting the jug into the head without any major force. I think that there is just a super precise fit. I will try to heating them a bit later today. |
Lo-Fi Version | Time is now: 17th June 2024 - 01:01 AM |
