tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
I have never had this issue before. I have new AMC heads and new EMW 96mm clyinders. I assembled the longblock to check valve train geometry. I need to send my heads off to get the valve guide bosses cut however I cannot remove the jugs from the heads. I do not want to break any fins so I haven't tried much other than muscle.
Any ideas? Attached image(s) ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
rubber mallet and some well placed taps (dont be shy) on the bottom of the cylinder all the way around.
Its only in the head less than a 1/4 if an inch...you just need to get it moving. I would send along the heads and one cylinder to the shop, those are too tight and could create a problem once heated up by the motor. Rich |
Lo-Fi Version | Time is now: 16th June 2024 - 10:58 PM |
