| Steve73 |
Jul 18 2011, 02:12 AM
Photographer/Shade Tree Mechanic ![]() ![]() Group: Members Posts: 125 Joined: 2-July 11 From: Nashville Member No.: 13,269 Region Association: South East States |
I'm trying to bring a dead 914 back to life. I have done the usual prep work and have hooked up the electrical system. The car turns over strongly but there is no spark! No spark at the plugs, no spark at the coil. I have switched the coil out with one I had laying around but i'm not getting any better results. Could it be the voltage regulator located in the box where the fuel injected controls are? (mine has been converted to dual carbs BTW).
What should I try next? Thanks in advance! |
| Steve73 |
Oct 7 2011, 11:48 PM
Thanks everyone but I still need some advice about the backfiring. I have the timing right for Carbs but I have what I think is a 009 distributor with no vacum attachments. Any adjustment advice is appreciated. I put up a vid of it running when I smooth out the engine. It does rev well with no hesitating or stalling.
| Prospectfarms |
Oct 8 2011, 09:48 PM
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
Thanks everyone but I still need some advice about the backfiring. I have the timing right for Carbs but I have what I think is a 009 distributor with no vacum attachments. Any adjustment advice is appreciated. I put up a vid of it running when I smooth out the engine. It does rev well with no hesitating or stalling. In my experience, when a "normal" engine "pops" while revving the throttle off idle, either the A/F mix is lean or the timing is incorrect. An OEM 914 distributor had a Bosch No. that end with 009; however, I think you are referencing the "Bosch 009 clone" or a new Bosch unit that are popular for aftermarket applications on AC VW engines. I've observed that 009 dizzy's (centrifugal) advance curve vary significantly between individual distributors, and that the advance comes-on suddenly. This means it's prudent to be conservative with timing when using these distributors. (OT) Without a vacuum advance, I'd imagine you'd feel a flat spot or hesitation when accelerating. |
Steve73 No spark! Jul 18 2011, 02:12 AM
corsepervita How is the voltage up to the coil? The grounding?
... Jul 18 2011, 03:52 AM
vsg914 Condensor Jul 18 2011, 05:01 AM
Prospectfarms Unlikely you have two bad coils. A good coil may n... Jul 18 2011, 07:34 AM
Steve73
Unlikely you have two bad coils. A good coil may ... Jul 18 2011, 10:39 AM
Drums66 ......Look at the grounding points, do them
coil ?... Jul 18 2011, 11:12 AM
codemasterlax i have the same problem with mine not getting spar... Sep 20 2011, 02:25 PM
Prospectfarms
i have the same problem with mine not getting spa... Sep 20 2011, 02:36 PM
underthetire
i have the same problem with mine not getting spa... Sep 20 2011, 02:44 PM
codemasterlax i do have in a bosch coil but wht bushings Sep 20 2011, 02:47 PM
underthetire Grab the rotor and try and wiggle it side to side.... Sep 20 2011, 02:51 PM
codemasterlax it does wiggle a lot but could tht also be because... Sep 20 2011, 02:56 PM
underthetire
it does wiggle a lot but could tht also be becaus... Sep 20 2011, 03:06 PM
codemasterlax ok what part exactly do i need to replace on the d... Sep 20 2011, 03:11 PM
underthetire You would need to disassemble the dizzy, Press the... Sep 20 2011, 03:53 PM
Cap'n Krusty And where is he going to find bushings? The wrong... Sep 20 2011, 05:05 PM
Prospectfarms
And where is he going to find bushings? The wron... Sep 20 2011, 07:01 PM
underthetire
And where is he going to find bushings? The wron... Sep 20 2011, 07:20 PM
Prospectfarms
And where is he going to find bushings? The wro... Sep 20 2011, 09:12 PM
Steve73 Prospect Farms Thanks for asking about my 914.
I ... Sep 21 2011, 01:56 AM
underthetire
I... Sep 21 2011, 08:59 AM
Steve73
[quote name='Steve73' post='1542174' date='Sep 21... Sep 25 2011, 09:53 PM
Steve73 I've got the engine running pretty well with t... Oct 7 2011, 03:23 PM
vsg914 44 is the low side of the dwell. 47 would be bette... Oct 7 2011, 04:13 PM
Prospectfarms Per: Pelican: timing with Carbs.
Set timing at 320... Oct 7 2011, 10:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 12:51 PM |
