| warrenoliver |
Oct 10 2011, 07:25 PM
Member ![]() ![]() Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
My '73, 2.0, Djet has been running great all summer! I noticed lately that it smells like gas when running and my mileage is poorer than usual. Yesterday when cruising at freeway speed it began running differently and would occasionally buck or shudder. It would run OK if I gave it more gas or let off on it a little. Today, it really smells like gas when running and sometimes runs really rough or wants to stall. When it runs rough, it smokes black smoke (running rich).
I put a vacuum tester on the MPS and can draw no vacuum. Is that how the MPS is tested? I had engine off with the ignition off when I tried to pull a vacuum. If the MPS is bad, will that cause the rich/rough running? I have placed a WTB in the classifieds. Any ideas on where to get a good used one? Help, I wanna drive a little more before we get the white stuff. Warrenoliver |
| Spoke |
Oct 11 2011, 07:38 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,355 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
When you say "draws no vacuum" for the MPS, do you mean you can't pump it up at all or it leaks down rather quickly?
The MPS senses the vacuum in the intake and adjusts the injector pulse width to match the vacuum. The MPS is the only sensor to the ECU to let the ECU know how much fuel to allow through the injectors. High vacuum = throttle closed = narrow pulse and little fuel. Low or no vacuum = throttle open widely = wide pulse and lots of fuel. I was able to fix my MPS with no vacuum by taking it apart and sealing things up. Now it holds vacuum very well. |
warrenoliver Running rough Oct 10 2011, 07:25 PM
dlee6204 If the MPS isn't holding vacuum then that is l... Oct 10 2011, 07:42 PM
somd914 Yes, testing is simply drawing a vacuum down with ... Oct 10 2011, 08:12 PM
somd914 Another thought as I have been down a very similar... Oct 11 2011, 03:32 AM
warrenoliver
When you say "draws no vacuum" for the ... Oct 11 2011, 06:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th March 2026 - 07:28 AM |
