| flipb |
Oct 15 2011, 02:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,871 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region
I've been noticing a slight grinding/vibration sensation through the front end whenever turning much off-center.
Today, I took my 914 to an open lift day at a local Porsche shop. I was just hoping to see if there was vertical play in the wheels, but my mechanic was kind enough to remove the front wheels and pull the outer bearing. It was in rough shape and he recommended that I should soon replace "all the bearings". (They are original on a car with at least 130K miles.) I've gathered there's inner & outer bearings for the front wheels, presume there's something roughly equivalent in the rear... So my questions are: 1. Can someone help me understand what "all the bearings" would include? 2. Pelican seems to have reasonably priced OEM-brand, is that what I want? 3. Anything else I should do "while I'm in there"? (No, not interested in 5-lug hubs.) |
| matthepcat |
Oct 15 2011, 11:36 PM
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Buy your bearings from Eric Shea here on the boards.
http://www.pmbperformance.com/ Videos: http://www.youtube.com/watch?v=T6CxhlpOvng&sns=em If you are installing yourself, let the new ones sit in the freezer a few days before install. Matt |
flipb Wheel bearings Oct 15 2011, 02:01 PM
flash914 Yes you most likely should change the rear. NO th... Oct 15 2011, 03:29 PM
rjames There are plenty of threads here showing how to do... Oct 16 2011, 02:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:20 PM |
