Penetrating oil study |
Harpo |
Oct 16 2011, 08:21 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Good morning everyone,
My mechanic at work gave me this information The April/May 2007 edition of Machinint's Workshop did a study on Penetrating oil. Penetrating Oil Chart Penetrating Oil Type Average load Cost per fluid ounce None 516 Lbs $0.00 WD-40 238 Lbs $0.25 PB Blaster 214 Lbs $0.35 Liquid Wrench 127 Lbs $0.21 Kano Kroil 106 Lbs $0.75 ATF-Acetone mix 53 Lbs $0.10 The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio) |
patssle |
Oct 16 2011, 06:50 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I can't believe it gets better than PB Blaster. I had to take the cat off my 911 exhaust and it was impossible with the nuts/bolts dry. A spray of PB and bam, those things came off easily.
dlkawashima |
Oct 16 2011, 07:03 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
"The April 2007 "Machinist's Workshop" magazine comparison
arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a scientifically rusted environment" *The ATF-Acetone mix was a "home brew" mix of 50% acetone - 50% automatic transmission fluid. **Note the "home brew" was better than any commercial product in this one particular test. ***Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price. |
Lo-Fi Version | Time is now: 11th June 2024 - 08:55 AM |
