Penetrating oil study |
Harpo |
Oct 16 2011, 08:21 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Good morning everyone,
My mechanic at work gave me this information The April/May 2007 edition of Machinint's Workshop did a study on Penetrating oil. Penetrating Oil Chart Penetrating Oil Type Average load Cost per fluid ounce None 516 Lbs $0.00 WD-40 238 Lbs $0.25 PB Blaster 214 Lbs $0.35 Liquid Wrench 127 Lbs $0.21 Kano Kroil 106 Lbs $0.75 ATF-Acetone mix 53 Lbs $0.10 The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio) |
Cevan |
Oct 17 2011, 04:53 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I'd like to see how this test was performed before I give it any weight. How did they calculate that the bolts were equally rusty?
pcar916 |
Oct 17 2011, 05:28 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
I'd like to see how this test was performed... I like details too but for something this simple just mix some up and try it so it leaps out of the theoretical realm. I keep it in a Nalgene container for the homemade stuff with a small capped pull-out hose. If you don't have a good delivery method it doesn't make any sense to mix it up. I've used this mixture for years but still have one can of Kroil around because spraying is occasionally handy. Kroil was all I used for many years, but since I always have ATF and acetone around, anything that works well and I don't have to go to the store for gets my vote! |
Lo-Fi Version | Time is now: 10th June 2024 - 05:17 PM |
