Penetrating oil study |
Harpo |
Oct 16 2011, 08:21 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Good morning everyone,
My mechanic at work gave me this information The April/May 2007 edition of Machinint's Workshop did a study on Penetrating oil. Penetrating Oil Chart Penetrating Oil Type Average load Cost per fluid ounce None 516 Lbs $0.00 WD-40 238 Lbs $0.25 PB Blaster 214 Lbs $0.35 Liquid Wrench 127 Lbs $0.21 Kano Kroil 106 Lbs $0.75 ATF-Acetone mix 53 Lbs $0.10 The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio) |
Cevan |
Oct 17 2011, 04:53 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I'd like to see how this test was performed before I give it any weight. How did they calculate that the bolts were equally rusty?
DBCooper |
Oct 18 2011, 07:20 AM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
I'd like to see how this test was performed before I give it any weight. How did they calculate that the bolts were equally rusty? There are ANSI tests for weathering, basically a salt spray in a chamber over an extended period, easy enough to get uniform corrosion. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:30 PM |
