| Spoke |
Oct 11 2011, 07:45 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,370 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I'm looking for a fuel pressure gauge to check my 71 D-Jet fuel pressure. Pelican has a kit to test FI fuel pressure but I was looking for a simple gauge that I could permanently attach to the fuel line.
Pelican FI Fuel Pressure Tester |
| Spoke |
Oct 18 2011, 08:59 AM
I bought the HF master kit and checked the fuel pressure. During the 2 sec pump run and running, the pressure was 27 lb/sq-in.
Is this ok or should I adjust it to 28.4-29.6 as per the repair manual? |
| jcd914 |
Oct 18 2011, 09:40 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I bought the HF master kit and checked the fuel pressure. During the 2 sec pump run and running, the pressure was 27 lb/sq-in. Is this ok or should I adjust it to 28.4-29.6 as per the repair manual? If it runs good I would probably leave it alone (1.4lbs could be your gauge). Lower pressure will mean slightly leaner mixture so if you are having and lean mixture symptoms I would bump it to specs. Jim |
Spoke Where to find FI Fuel Pressure Gauge? Oct 11 2011, 07:45 AM
vsg914 I got a cheapy gauge at Oriellys. Doesn't have... Oct 11 2011, 07:50 AM
rick 918-S Harbor Freight has two of them. One low buck gauge... Oct 11 2011, 07:54 AM
914_teener
Harbor Freight has two of them. One low buck gaug... Oct 11 2011, 11:08 PM
Cap'n Krusty
I'm looking for a fuel pressure gauge to chec... Oct 11 2011, 07:56 AM
Als914 Look through Jeg's offerings. http://www.jegs.... Oct 11 2011, 08:14 AM
BigDBass I got the Fuel Pressure Gauge Kit from 9x Auto her... Oct 11 2011, 10:06 AM
ConeDodger I've gotten mine through Summit racing in the ... Oct 11 2011, 05:20 PM
RON S. I got mine from Jegs, IIRC.
I think it was o... Oct 11 2011, 06:25 PM
Spoke I really only want to check or set the fuel pressu... Oct 11 2011, 07:56 PM
Prospectfarms As already said, almost any pressure gauge will do... Oct 11 2011, 08:55 PM
Cap'n Krusty
I bought the HF master kit and checked the fuel p... Oct 18 2011, 10:35 AM
Prospectfarms
Obsession with irrelevant minutiae is often caus... Oct 18 2011, 12:31 PM
Tom I don't know the accuracy of the gages folks a... Oct 18 2011, 11:12 AM
Spoke Thanks for all the input. My only reason for check... Oct 18 2011, 02:35 PM
Prospectfarms What did you determine? Was low fuel pressure caus... Oct 18 2011, 03:53 PM
underthetire ALL gauges that we as the consumer are willing to ... Oct 18 2011, 04:10 PM
76-914 :agree: Tom is right. Vibration kill gages. Glycer... Oct 18 2011, 04:35 PM
Tom I calibrated gages for a while some years ago. mos... Oct 18 2011, 06:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:16 PM |
