| 914Bryan |
Oct 14 2011, 05:54 PM
Member ![]() ![]() Group: Members Posts: 190 Joined: 6-June 11 From: Orange County Member No.: 13,162 Region Association: Southern California |
What can I do about a bouncing tach? When I shift, the needle wildly bounces around until the rpm settles in a gear. Then it either climbs or drops depending on acceleration or decelaration. Any ideas? (IMG:style_emoticons/default/confused24.gif)
74 2.0, stock fi and dizzy/coil |
| Spoke |
Oct 16 2011, 10:20 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,438 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
There's 2 basic reasons the tach bounces:
1) Points opening and closing causes transients causing bouncing almost anytime the engine is running even a constant RPM. This happens when you have points-issues. 2) The early model tach needles do not have sufficient damping to prevent under shoot and over shoot when the RPM changes. Change the RPM and the needle oscillates back and forth and finally settles to the correct RPM. See the general step responses below (step being from one RPM level to another). If the tach is not damped enough, it oscillates. To damp the 914 tach, simply connect a 2200uF capacitor across the needle winding as shown below. This will transform the operation of the tach to be like tachs in today's cars which never bounce or oscillate. Attached image(s)
| Valy |
Oct 16 2011, 10:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
My dear friend, you solved a symptom, not the root cause. I'm sure the German engineer that designed the tach knew how to attenuate the bouncing but didn't do so cause there was no need. The capacitor on the distributor is supposed to smooth that bouncing. If the capacitor is dead, the bouncing will be there. If you changed the capacitor and the bouncing is still there, I bet the coil has a short between the winding on the high voltage side (almost dead coil). |
| Spoke |
Oct 17 2011, 07:02 AM
My dear friend, you solved a symptom, not the root cause. I'm sure the German engineer that designed the tach knew how to attenuate the bouncing but didn't do so cause there was no need. The capacitor on the distributor is supposed to smooth that bouncing. If the capacitor is dead, the bouncing will be there. If you changed the capacitor and the bouncing is still there, I bet the coil has a short between the winding on the high voltage side (almost dead coil). Keep in mind we're talking about 2 different scenarios: 1) Issues with points/condenser/ignition. Issues with the points/condenser will cause the tach to bounce or jump/drop without warning as the car is running. Electronic points and properly adjusted and functioning points/condenser should cure this. 2) Design of the tachometer itself. I could imagine that back in the 50s or 60s when the tach was designed, a faster response may have been desired over a tach that does not overshoot. Note that a fast response will get the needle faster to the correct value but will overshoot and oscillate at a frequency dependent on the design of the needle electronics and mechanicals. In this case calling the tach phenomena as bouncing is not as correct as calling it a fundamental oscillation of the needle response to a step input. So the capacitor across the tach windings settles the tach needle from fundamental oscillation but does nothing about issues with the points/condenser. I put the capacitor on the tach in my 74 and it solved all oscillations and made the tach respond like in my 86 930 and all the other new cars I have. It responded beautifully. BTW, my car has has Petronix electronic points. |
| Valy |
Oct 18 2011, 07:26 PM
My dear friend, you solved a symptom, not the root cause. I'm sure the German engineer that designed the tach knew how to attenuate the bouncing but didn't do so cause there was no need. The capacitor on the distributor is supposed to smooth that bouncing. If the capacitor is dead, the bouncing will be there. If you changed the capacitor and the bouncing is still there, I bet the coil has a short between the winding on the high voltage side (almost dead coil). Keep in mind we're talking about 2 different scenarios: 1) Issues with points/condenser/ignition. Issues with the points/condenser will cause the tach to bounce or jump/drop without warning as the car is running. Electronic points and properly adjusted and functioning points/condenser should cure this. 2) Design of the tachometer itself. I could imagine that back in the 50s or 60s when the tach was designed, a faster response may have been desired over a tach that does not overshoot. Note that a fast response will get the needle faster to the correct value but will overshoot and oscillate at a frequency dependent on the design of the needle electronics and mechanicals. In this case calling the tach phenomena as bouncing is not as correct as calling it a fundamental oscillation of the needle response to a step input. So the capacitor across the tach windings settles the tach needle from fundamental oscillation but does nothing about issues with the points/condenser. I put the capacitor on the tach in my 74 and it solved all oscillations and made the tach respond like in my 86 930 and all the other new cars I have. It responded beautifully. BTW, my car has has Petronix electronic points. The problem is that the bouncing fools the tach to see a double RPM value. You need to filter that. Just adding a capacitor on the tach winding will force the tach to average the input information so the needle will move with delay. The best thing is to solve the rot cause. This will also improve the spark. |
| Spoke |
Oct 19 2011, 04:40 AM
The problem is that the bouncing fools the tach to see a double RPM value. You need to filter that. Just adding a capacitor on the tach winding will force the tach to average the input information so the needle will move with delay. The best thing is to solve the rot cause. This will also improve the spark. I think you're talking about points issues and I agree 100% with you. On my 71, with Pertronix electronic ignition, I get no contact or points bouncing. The tach design allows for significant overshoot with fast RPM changes. I get harmonic oscillation when I downshift or upshift. I've observed at most a 1000 RPM overshoot when downshifting. I would estimate the oscillation to have a time constant of about 1/4 second. When downshifting to a higher RPM, the overshoot goes as much as 1000 RPM over, then undershoots once and settles at the correct RPM. |
914Bryan Tach Bounce Oct 14 2011, 05:54 PM
Dave_Darling If your car still has ignition points, check them ... Oct 14 2011, 06:22 PM
Valy
What can I do about a bouncing tach? When I shift... Oct 14 2011, 06:23 PM
914Bryan I was thinking points too..Side note, I was thinki... Oct 14 2011, 07:08 PM
Vacca Rabite If you are running Djet, you need to keep the stoc... Oct 14 2011, 07:50 PM
avidfanjpl Get a pertronix for that car. I only keep points a... Oct 14 2011, 11:47 PM
Valy Just for reference, this is what your bad points/c... Oct 15 2011, 02:07 AM
914Bryan Awesome info guys! Thanks! Oct 15 2011, 05:42 PM
Tom Valy,
That is some bad switch bounce! The... Oct 15 2011, 07:40 PM
michael7810 My tach does the same thing. I have a new distrib... Oct 15 2011, 08:09 PM
mgphoto
My tach does the same thing. I have a new distri... Oct 17 2011, 10:59 AM
914Bryan Sooo maybe an Autometer monster tach instead of th... Oct 15 2011, 08:26 PM
Vacca Rabite I don't suppose you could point out the cap th... Oct 16 2011, 10:41 AM
Bartlett 914
I don't suppose you could point out the cap t... Oct 16 2011, 02:38 PM
Spoke
My Tach jumps also. I don't remember which c... Oct 16 2011, 07:05 PM
Spoke
I don't suppose you could point out the cap t... Oct 16 2011, 07:01 PM
9146986 Sometimes just putting a clean piece of thin cardb... Oct 17 2011, 10:46 AM
larss I had about the same symptoms on my tach, the need... Oct 17 2011, 11:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 06:39 AM |
