Alternator Output not keeping up with audio system |
Kansas 914 |
Oct 25 2011, 11:14 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I installed a Boston Acoustics GTA-504 and since install I have not been able to charge the battery during long drive with the music cranked up. I really thought the 55AMP alternator would have been fine for the small amp.
I am running 6.5" separates on 2 channels and bridged the other 2 channels to mono for the sub. All speakers are 4 ohm. There are two 25A fuses on the amp and I added a single 60A in-line at the battery for the power to the amp. No fuses have ever blown - but I wondered if the alternator is actually cranking out 55 Amps. If I don't drive with the music on it works and charges the battery fine. I think I might just install a bus alternator (75Amps) unless others think it is a mistake. Link to install manual: http://www.bostonacoustics.com/PDFs/manual..._2_4_Ch_Man.pdf Quick Specs: |
VaccaRabite |
Oct 25 2011, 11:26 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Lots of things here
Corrosion at connectors force more current draw then expected. It may not be enought to pop a fuse, but a little will add up when the alt is at the limit. The alt may not actually produce 55 amps any more. If you have better headlights, horns, fuel pump, oil cooler, AC, they are all sapping more power then was designed. Voltage regulator may be slightly wiggy. Too many variables. Do a load test and see what kind of power you are really making. |
Lo-Fi Version | Time is now: 13th June 2024 - 10:33 AM |
