Alternator Output not keeping up with audio system |
Kansas 914 |
Oct 25 2011, 11:14 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I installed a Boston Acoustics GTA-504 and since install I have not been able to charge the battery during long drive with the music cranked up. I really thought the 55AMP alternator would have been fine for the small amp.
I am running 6.5" separates on 2 channels and bridged the other 2 channels to mono for the sub. All speakers are 4 ohm. There are two 25A fuses on the amp and I added a single 60A in-line at the battery for the power to the amp. No fuses have ever blown - but I wondered if the alternator is actually cranking out 55 Amps. If I don't drive with the music on it works and charges the battery fine. I think I might just install a bus alternator (75Amps) unless others think it is a mistake. Link to install manual: http://www.bostonacoustics.com/PDFs/manual..._2_4_Ch_Man.pdf Quick Specs: |
Spoke |
Oct 25 2011, 01:39 PM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Not charging the battery with the amp can be tested with a voltmeter on the battery.
You can test this by running the car at about 2k RPM with all electrical appliances off and a voltmeter on the battery. Monitor the battery voltage and turn on electrical appliances one by one; lights, amp, etc. and see when the battery voltage drops. |
Lo-Fi Version | Time is now: 13th June 2024 - 05:46 PM |
