| 914_classic |
Oct 26 2011, 03:48 PM
Newbie ![]() Group: Members Posts: 12 Joined: 2-April 11 From: West Michigan Member No.: 12,887 Region Association: Upper MidWest |
I'm starting a 2.0 build and I have set of idf 40's but I don't know if they'll keep up. It's going to have the biggest cylinders and pistons I can buy in it with a knife edged and balanced crank, port and polished heads, big cam... Blah blah blah. I have a set of IDF 40s and I am wondering if they will be able to keep up. Any help would be appreciated.
| jmill |
Oct 26 2011, 04:18 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
We need a little more info than that. First off, is this going to be a low RPM DD or a high RPM track car? How big is big and how fast are you going to spin it?
You'll need to calculate your venturi size based on cylinder capacity and RPM. Once you determine your venturi size does it fit in the IDF 40 carb body? Also remember that venturi selection is going to be a compromise between high speed performance and low speed drivability. |
914_classic Carb questions? Oct 26 2011, 03:48 PM
kg6dxn The biggest would make your engine a 3.6L. Is that... Oct 26 2011, 04:16 PM
John Is this a 4-cyl engine? Are you using dual 40s?
... Oct 26 2011, 05:28 PM
Vacca Rabite
I'm starting a 2.0 build and I have set of id... Oct 26 2011, 05:42 PM
914_classic I am an engine builder and have enough knowledge o... Oct 31 2011, 08:29 PM
Jake Raby If you are looking for hi RPM then high volume wil... Oct 31 2011, 09:25 PM
914_classic That was exactly what i was looking for, thanks so... Oct 31 2011, 10:34 PM
jmill
Are DCOE's worth trying? Im a pretty big wate... Nov 2 2011, 10:49 AM
914_classic Thanks! I'm not super familiar with carbs,... Nov 3 2011, 04:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 11:47 AM |
