| 914_classic |
Oct 26 2011, 03:48 PM
Newbie ![]() Group: Members Posts: 12 Joined: 2-April 11 From: West Michigan Member No.: 12,887 Region Association: Upper MidWest |
I'm starting a 2.0 build and I have set of idf 40's but I don't know if they'll keep up. It's going to have the biggest cylinders and pistons I can buy in it with a knife edged and balanced crank, port and polished heads, big cam... Blah blah blah. I have a set of IDF 40s and I am wondering if they will be able to keep up. Any help would be appreciated.
| VaccaRabite |
Oct 26 2011, 05:42 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,856 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I'm starting a 2.0 build and I have set of idf 40's but I don't know if they'll keep up. It's going to have the biggest cylinders and pistons I can buy in it with a knife edged and balanced crank, port and polished heads, big cam... Blah blah blah. I have a set of IDF 40s and I am wondering if they will be able to keep up. Any help would be appreciated. before you spend thousands on parts and end up with a trainwreck of an engine, please research what makes power without killing the engine with heat. 40s will be fine for a 2.0. Most would say they would be idea. 44s will work, but will give you all the power in the top end. Zach |
914_classic Carb questions? Oct 26 2011, 03:48 PM
kg6dxn The biggest would make your engine a 3.6L. Is that... Oct 26 2011, 04:16 PM
jmill We need a little more info than that. First off, ... Oct 26 2011, 04:18 PM
John Is this a 4-cyl engine? Are you using dual 40s?
... Oct 26 2011, 05:28 PM
914_classic I am an engine builder and have enough knowledge o... Oct 31 2011, 08:29 PM
Jake Raby If you are looking for hi RPM then high volume wil... Oct 31 2011, 09:25 PM
914_classic That was exactly what i was looking for, thanks so... Oct 31 2011, 10:34 PM
jmill
Are DCOE's worth trying? Im a pretty big wate... Nov 2 2011, 10:49 AM
914_classic Thanks! I'm not super familiar with carbs,... Nov 3 2011, 04:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 11:46 AM |
