> Question for those that weld floor pans
MrHyde
post Oct 26 2011, 04:50 PM
I'm almost ready to start fitting the rear floor pan section and weld it in, but i have one question.. When I cut the old floor pan out, I cut it short by about an inch to inch and half.. I figured at the time I would trim it for a proper fit and sort it out when I was ready to weld.. Well that time is here.
Should I cut the old floor back so that the new floor pan butts up against it and butt weld the whole cut line (not as pleasant ) or perhaps pull down on the extra inch or so ( after drilling out the spot welds ) of old floor pan and have the old floor overlap the new floor pan and join it with two fillet welds.. I'm thinking that it might be stronger if I overlap the floor sections but I might be way off base here.. What would you guys do?? set it up to butt weld the floor sections together or set it up to overlap the floor sections.???
Thanks !
Mike
r_towle
post Oct 27 2011, 12:09 PM
Custom Member
The correct way (IMHO) is to remove the floor pans just like they were installed by drilling out all the spot welds on the bottom of the car.
Then put the pan under the car, jack it up and weld it back in place...just like its meant to be done.
That is why the pan is so large...it actually goes under the car, it does not come in from above.
RIch
post Oct 27 2011, 01:45 PM
Resident German
QUOTE(r_towle @ Oct 27 2011, 11:09 AM) *
The replacement pans are large enough. Drill holes and "spot" weld it back into place.
(IMG:style_emoticons/default/welder.gif)
- Lo-Fi Version Time is now: 7th November 2026 - 08:51 PM
