> HELP: Removing Axle's/CV joints from trailing arms, what tricks or secrets in removing them? I can't get mine off...Grrrr
Mr.242
post Oct 27 2011, 09:55 PM
May your glass be smaller so it's always FULL!
Having removed the Engine and Tranny. Prep for the car to head to the paint process. I want to remove and rebuild the axle and CV joints.
I can't get them to come loose. Am I missing something?
(IMG:style_emoticons/default/pray.gif) Any help would be appreciated. Thanks!
rwilner
post Oct 27 2011, 10:06 PM
No Ghosts in the Machine
Assuming you removed the 4 12-star bolts, you can try simply pulling on them. I got mine off this way but had to be very aggressive.
The only other way I know of is to remove the castle nut that connects the stub axle to the hub. Then you can pull the stub axle / CV joint / half shaft off as an assembly and separate them on the bench, which is easy. Removing that whole assembly can be challenging with the trans in place due to clearance issues, but since your drivetrain is removed, removal should be a snap.
Removing that castle nut will require a breaker bar, I think the factory spec is 200 ft lbs (or more). Don't forget to take out the cotter pin first!
good luck, and if you need help servicing your CV joints, search "914 cv joints" on youtube for a pair of videos that are an awesome walkthrough.
Mr.242   HELP: Removing Axle's/CV joints from trailing arms   Oct 27 2011, 09:55 PM
rwilner   Assuming you removed the 4 12-star bolts, you can ...   Oct 27 2011, 10:06 PM
jcd914   If you remove the stub axles don't roll the ca...   Oct 27 2011, 10:16 PM
JRust   Having removed the Engine and Tranny. Prep for t...   Oct 27 2011, 10:24 PM
Cap'n Krusty   Having removed the Engine and Tranny. Prep for ...   Oct 27 2011, 11:28 PM
Mr.242   I am pulling and pounding like crazy on these....w...   Oct 27 2011, 10:30 PM
Elliot Cannon   I am pulling and pounding like crazy on these.......   Oct 27 2011, 10:31 PM
Mr.242   Some pictures might help. Show us what you...   Oct 27 2011, 11:12 PM
Mr.242   Okay, Okay, Okay.....I couldn't resist. Here ...   Oct 27 2011, 11:19 PM
nathansnathan   Okay, Okay, Okay.....I couldn't resist. Here...   Oct 28 2011, 07:06 AM
Mr.242   So I have asked: What is it that YOU do to get th...   Oct 28 2011, 07:03 AM
vsg914   So I have asked: What is it that YOU do to get t...   Oct 28 2011, 07:31 AM
rohar   Just a sec, it isn't quite clear. You trying ...   Oct 28 2011, 08:13 AM
rohar   If you're trying to remove the axle with the s...   Oct 28 2011, 08:39 AM
jimkelly   mr.242 - firstly congrats ; )) secondly - have yo...   Oct 28 2011, 08:49 AM
stugray   He is just trying to separate the CV from the stub...   Oct 28 2011, 09:38 AM
jcd914   He is just trying to separate the CV from the stu...   Oct 28 2011, 09:48 AM
vsg914   He is just trying to separate the CV from the st...   Oct 28 2011, 10:27 AM
tradisrad   [quote name='jcd914' post='1562816' date='Oct 28 ...   Nov 28 2011, 12:10 PM
zx-niner   He is just trying to separate the CV from the st...   Oct 29 2011, 12:09 PM
rjames   How old are your rear bearings? If you think they ...   Oct 28 2011, 09:55 AM
Jeffs9146   I wrap a comealong around the axel and the trailin...   Oct 28 2011, 10:56 AM
vsg914   I wrap a comealong around the axel and the traili...   Oct 28 2011, 11:09 AM
Jeffs9146   Deleted   Oct 28 2011, 10:57 AM
Tom   Call Mike, hasn't he done this? Pretty sure...   Oct 28 2011, 12:47 PM
stugray   "Pretty sure you can remove the whole axle wi...   Oct 28 2011, 03:21 PM
Mr.242   I wrap a comealong around the axel and the traili...   Oct 29 2011, 11:26 AM
Jeffs9146   I wrap a comealong around the axel and the trail...   Oct 29 2011, 11:51 AM
Dr Evil   The only thing holding it on at this point are two...   Oct 29 2011, 12:15 PM
Mr.242   The only thing holding it on at this point are tw...   Oct 29 2011, 12:48 PM
Mr.242   Well they are OFF. I had to have Mike come over w...   Nov 28 2011, 10:26 AM
SirAndy   All those other methods didn't work and after ...   Nov 28 2011, 08:27 PM
6freak   he just needed to call big brother with the right ...   Nov 28 2011, 10:52 AM
6freak   [ the right tools :) just so ya know a Dewalt ...   Nov 28 2011, 01:39 PM
JRust   [ the right tools :) just so ya know a Dewalt 1...   Nov 28 2011, 02:44 PM
6freak   [ the right tools :) just so ya know a Dewalt ...   Nov 29 2011, 08:55 AM
PeeGreen 914   he just needed to call big brother with the right...   Nov 28 2011, 06:00 PM
tod914   Alittle late to respond. But, after struggeling wi...   Nov 28 2011, 04:22 PM
Mr.242   he just needed to call big brother with the righ...   Nov 28 2011, 08:20 PM
Mr.242   All those other methods didn't work and after...   Nov 28 2011, 10:35 PM
jhynesrockmtn   Thankful to have found this older thread. Just pu...   Jul 8 2023, 02:51 PM
Geezer914   There is a you tube video that an older VW mechani...   Jul 8 2023, 03:31 PM
- Lo-Fi Version Time is now: 4th September 2026 - 11:56 PM
