| Mr.242 |
Oct 27 2011, 09:55 PM
May your glass be smaller so it's always FULL! ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
Having removed the Engine and Tranny. Prep for the car to head to the paint process. I want to remove and rebuild the axle and CV joints.
I can't get them to come loose. Am I missing something? (IMG:style_emoticons/default/pray.gif) Any help would be appreciated. Thanks! |
| stugray |
Oct 28 2011, 09:38 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
He is just trying to separate the CV from the stub axle, so the axle does not need to come out.
In fact, I was told (on this forum) that if you pound out the stub from the bearings, you will ruin the bearings. I dont totally agree with that since my haynes manual actually has a picture of someone driving the axle out with a soft blow hammer. It does not state that you need to replace the wheel bearings afterward. Stu |
| jcd914 |
Oct 28 2011, 09:48 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
He is just trying to separate the CV from the stub axle, so the axle does not need to come out. Some will cring at this but... After the all the bolts on the outer joint are loose or out I usually just take the inner joint raise it up and slam it down, turn the wheel 90degrees and repeat. Inner joint pops loose fairly quickly. Jim |
| TheCabinetmaker |
Oct 28 2011, 10:27 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
He is just trying to separate the CV from the stub axle, so the axle does not need to come out. Some will cring at this but... After the all the bolts on the outer joint are loose or out I usually just take the inner joint raise it up and slam it down, turn the wheel 90degrees and repeat. Inner joint pops loose fairly quickly. Jim I might just give that a try next time Jim. |
Mr.242 HELP: Removing Axle's/CV joints from trailing arms Oct 27 2011, 09:55 PM
rwilner Assuming you removed the 4 12-star bolts, you can ... Oct 27 2011, 10:06 PM
jcd914 If you remove the stub axles don't roll the ca... Oct 27 2011, 10:16 PM
JRust
Having removed the Engine and Tranny. Prep for t... Oct 27 2011, 10:24 PM
Cap'n Krusty
Having removed the Engine and Tranny. Prep for ... Oct 27 2011, 11:28 PM
Mr.242 I am pulling and pounding like crazy on these....w... Oct 27 2011, 10:30 PM
Elliot Cannon
I am pulling and pounding like crazy on these....... Oct 27 2011, 10:31 PM
Mr.242
Some pictures might help. Show us what you... Oct 27 2011, 11:12 PM
Mr.242 Okay, Okay, Okay.....I couldn't resist.
Here ... Oct 27 2011, 11:19 PM
nathansnathan
Here... Oct 28 2011, 07:06 AM
Mr.242 So I have asked: What is it that YOU do to get th... Oct 28 2011, 07:03 AM
vsg914
So I have asked: What is it that YOU do to get t... Oct 28 2011, 07:31 AM
rohar Just a sec, it isn't quite clear. You trying ... Oct 28 2011, 08:13 AM
rohar If you're trying to remove the axle with the s... Oct 28 2011, 08:39 AM
jimkelly mr.242 - firstly congrats ; ))
secondly - have yo... Oct 28 2011, 08:49 AM
tradisrad
[quote name='jcd914' post='1562816' date='Oct 28 ... Nov 28 2011, 12:10 PM
zx-niner
He is just trying to separate the CV from the st... Oct 29 2011, 12:09 PM
rjames How old are your rear bearings? If you think they ... Oct 28 2011, 09:55 AM
Jeffs9146 I wrap a comealong around the axel and the trailin... Oct 28 2011, 10:56 AM
vsg914
I wrap a comealong around the axel and the traili... Oct 28 2011, 11:09 AM
Jeffs9146 Deleted Oct 28 2011, 10:57 AM
Tom Call Mike, hasn't he done this?
Pretty sure... Oct 28 2011, 12:47 PM
stugray "Pretty sure you can remove the whole axle wi... Oct 28 2011, 03:21 PM
Mr.242
I wrap a comealong around the axel and the traili... Oct 29 2011, 11:26 AM
Jeffs9146
I wrap a comealong around the axel and the trail... Oct 29 2011, 11:51 AM
Dr Evil The only thing holding it on at this point are two... Oct 29 2011, 12:15 PM
Mr.242
The only thing holding it on at this point are tw... Oct 29 2011, 12:48 PM
Mr.242 Well they are OFF.
I had to have Mike come over w... Nov 28 2011, 10:26 AM
SirAndy All those other methods didn't work and after ... Nov 28 2011, 08:27 PM
6freak he just needed to call big brother with the right ... Nov 28 2011, 10:52 AM
6freak [ the right tools :)
just so ya know a Dewalt ... Nov 28 2011, 01:39 PM
JRust
just so ya know a Dewalt 1... Nov 28 2011, 02:44 PM
6freak
just so ya know a Dewalt ... Nov 29 2011, 08:55 AM
PeeGreen 914
he just needed to call big brother with the right... Nov 28 2011, 06:00 PM
tod914 Alittle late to respond. But, after struggeling wi... Nov 28 2011, 04:22 PM
Mr.242
he just needed to call big brother with the righ... Nov 28 2011, 08:20 PM
Mr.242
All those other methods didn't work and after... Nov 28 2011, 10:35 PM
jhynesrockmtn Thankful to have found this older thread. Just pu... Jul 8 2023, 02:51 PM
Geezer914 There is a you tube video that an older VW mechani... Jul 8 2023, 03:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th September 2026 - 11:55 PM |
