> Engine idle raise drop, cold… DJet help., up/down/up/down....
broomhandle
post Oct 27 2011, 11:03 AM
My 1.7 when started, the idle will go up and down, even for about an hour of driving. After an hour (here or there) the idle stays up and drops for awhile. And then it is fine… but can drop back down sometimes. On hotter days, it seems like it is faster to a normal running idle.
I had 4 ideas:
1.)Cold temp sensors, I know there are 2 but I am unsure about it. Or how to test.
2.)Fuel/vacuum. This was my 1st thought, so I have new lines around the motor and the top of the tank. And the injectors have been re-built. but still could be djet.
3.)I have a really old muffler that needs replacing. warms up, can breate...
4.)Air in. (I know ill start some fights here, but it has the oil mess, I swear it can not get enough air)
Any ideas? It’s a daily driver, and it is annoying as heck.
Thestigz06
post Oct 28 2011, 01:35 PM
Aspiring Jarhead
Make sure the o-rings around the injectors are not deteriorated. all you have to do is try and move the injector up and down. if it moves, new o-ring on the injector.
broomhandle   Engine idle raise drop, cold… DJet help.   Oct 27 2011, 11:03 AM
Philip W.   Engine idle raise drop, cold… DJet help. My 1...   Oct 27 2011, 11:08 AM
Philip W.   Engine idle raise drop, cold… DJet help. My ...   Oct 27 2011, 11:25 AM
broomhandle   MSP and AAR?   Oct 27 2011, 11:19 AM
r_towle   Check your TPS setting and make sure youare really...   Oct 27 2011, 11:20 AM
McMark   Vacuum leaks.   Oct 27 2011, 11:30 AM
r_towle   Vacuum leaks. That too. To expand on this. I do...   Oct 27 2011, 12:03 PM
broomhandle   i thought it was vac lines as well, but i replaced...   Oct 27 2011, 12:14 PM
Philip W.   i thought it was vac lines as well, but i replace...   Oct 27 2011, 01:20 PM
r_towle   MPS is manifold pressure sensor...the little pinap...   Oct 27 2011, 12:58 PM
broomhandle   Cool, thanks guys.... this will keep me busy on sa...   Oct 27 2011, 02:04 PM
McMark   You're assuming new lines = not vacuum leaks....   Oct 27 2011, 02:24 PM
Rand   Hunting idle means lean, which probably means vacu...   Oct 27 2011, 02:28 PM
broomhandle   Hunting idle means lean, which probably means vac...   Oct 27 2011, 02:50 PM
Rand   Hunting idle means lean, which probably means va...   Oct 27 2011, 03:06 PM
Spoke   Does the idle hunting oscillate quickly, like once...   Oct 27 2011, 03:19 PM
broomhandle   Does the idle hunting oscillate quickly, like onc...   Oct 27 2011, 03:58 PM
Rand   That's a pretty significant vacuum leak. Does ...   Oct 27 2011, 04:02 PM
broomhandle   That's a pretty significant vacuum leak. Does...   Oct 27 2011, 04:06 PM
Thestigz06   Make sure the o-rings around the injectors are not...   Oct 28 2011, 01:35 PM
Spoke   With the engine idling, spray carb cleaner on all ...   Oct 28 2011, 02:27 PM
- Lo-Fi Version Time is now: 16th July 2025 - 05:14 AM
