| TheCabinetmaker |
Oct 26 2011, 07:12 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,366 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Just reinstalled my new engine before musr12. Its a 2056 with Raby 9550 cam and djet. I reinstalled the original FI system complete. Components were bench tested before being reinstalled. Car runs beyond my expections.
Heres the only problem I have really have. Upon cold start (not cold-cold start) it idles very low and rough. A few minutes of throttle held to about 1400 rpms, and the aar kicks in and everything is normal from there. Or, if I start it and pull it out of the garage to the drive, everything is normal. Aar is working properly. Head temp sensor is the correct one and ohms are within specs both hot and cold. Ts-1 also shows 310 ohms at 60 degrees. Cold start valve is not hooked up. I have considered a leaky injector, but is seems that would cause problems only when there is adquate fuel pressure, not after setting all night. Ambient temp seems to make no difference. Opinions please. |
| PancakePorsche |
Oct 29 2011, 02:27 AM
Member ![]() ![]() Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
My stock engine does the exact same thing. My AAR also works as it should. In my case mixture is over rich for the first couple minutes. It will smooth out if I lean the ECU knob, but will lean surge once up to normal operating temp. It is a balancing act I just learned to live with. I suspect the resistance curve of the head sensor just is not ideal. I am still amazed these old analog open loop systems work as well as they do ! Still getting 30 MPG with my 2.0
vsg914 D-jet guys Oct 26 2011, 07:12 AM
rmital D-Jetronic Idle Stability (from Brad's site)
... Oct 26 2011, 07:29 AM
vsg914 Thanks Ray, but that isn't the symptom . This ... Oct 26 2011, 07:34 AM
rmital
Thanks Ray, but that isn't the symptom . This... Oct 26 2011, 07:36 AM
vsg914 No prob, Ray. Cold-cold start refers to temps unde... Oct 26 2011, 07:42 AM
tradisrad you say when the AAR valve kicks in; do you mean w... Oct 26 2011, 08:00 AM
914_teener
you say when the AAR valve kicks in; do you mean ... Oct 26 2011, 08:10 AM
vsg914
you say when the AAR valve kicks in; do you mean... Oct 26 2011, 08:31 AM
vsg914 AAR works as designed. It opens fully cold and clo... Oct 26 2011, 08:05 AM
Thomas J Bliznik D-Jet Guys,
I had the same problem with my Raby #... Oct 26 2011, 08:28 AM
sfrenck
D-Jet Guys,
I had the same problem with my Raby ... Oct 26 2011, 08:54 AM
vsg914
D-Jet Guys,
I had the same problem with my Raby... Oct 26 2011, 09:16 AM
r_towle most likely too rich at idle.
Turn down the knob o... Oct 26 2011, 10:07 AM
vsg914 Rich, running rich is my thought too. Yes an o2 se... Oct 26 2011, 10:19 AM
r_towle MPS needs to be set under load...even with an O2 s... Oct 26 2011, 10:31 AM
Tom_T Not sure of the cause nor cure Curt, but you'l... Oct 28 2011, 09:13 PM
Bleyseng Its too rich at startup due to the 9550 cam. 1100 ... Oct 29 2011, 04:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th March 2026 - 11:13 PM |
