> Oval end of the door jamb vent tube..., how is it fastened to the inner ply?
TargaToy
post Oct 29 2011, 02:00 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO-
Sorry for the crappy pics. Shot 'em fast for the sake of the question.
A member here (thanks Doug!) hooked me up with some good vent tubes/door handle recesses to replace the rotten ones in my car.
I'm cleaning them up and removing the sealer, etc.
How are the oval ends of the tubes fastened to the inner ply? It appears there's an oval inside an oval (2 plys) if that makes sense. Are they spot welded together? Brazed? Friction fit?
I'm trying to get the oval end of the tube out of the inner skin while keeping the round end attached to the jamb end.
partwerks
post Oct 30 2011, 02:26 PM
I was wondering if those in the door are for the purpose of when closing the door, so the air in the cab has somewhere to go to so it will close easier, or is it for some other purpose?
TargaToy   Oval end of the door jamb vent tube...   Oct 29 2011, 02:00 PM
PanelBilly   Rust   Oct 29 2011, 02:11 PM
rdauenhauer   Friction & brazing   Oct 29 2011, 02:24 PM
TargaToy   "Friction and brazing". So if I hit the...   Oct 29 2011, 02:35 PM
rdauenhauer   Depends on the car & the level of focus of the...   Oct 29 2011, 09:48 PM
TargaToy   I hit the oval lip a bit with a wire wheel and it ...   Oct 30 2011, 12:01 PM
JMKnight   :WTF: Awful lot of work .   Oct 30 2011, 12:18 PM
TargaToy   " :WTF: Awful lot of work ." See my oth...   Oct 30 2011, 12:25 PM
nathansnathan   I've got a piece just like that, now blasted. ...   Oct 30 2011, 01:31 PM
TargaToy   I've got a piece just like that, now blasted....   Oct 30 2011, 02:32 PM
sean_v8_914   be careful when welding that area. I have done a f...   Oct 30 2011, 01:46 PM
TargaToy   be careful when welding that area. I have done a ...   Oct 30 2011, 02:35 PM
partwerks   I was wondering if those in the door are for the p...   Oct 30 2011, 02:26 PM
TargaToy   I was wondering if those in the door are for the ...   Oct 30 2011, 02:34 PM
dlee6204   I was wondering if those in the door are for the...   Oct 30 2011, 02:51 PM
partwerks   ya. Like blowing in a bottle w/o a hole on the oth...   Oct 30 2011, 02:57 PM
nathansnathan   I just took the tube out of my car. Here's the...   Oct 30 2011, 03:59 PM
TargaToy   Thanks for nothing. Now I've got to explain t...   Oct 30 2011, 07:37 PM
nathansnathan   The same part before may help you make your case, ...   Oct 30 2011, 10:37 PM
TargaToy   What media did you use to clean up the donor parts...   Oct 31 2011, 08:28 PM
nathansnathan   What media did you use to clean up the donor part...   Nov 1 2011, 05:28 AM
TargaToy   Dumb question but what media would be a "no-n...   Nov 1 2011, 07:21 PM
nathansnathan   Picking out media, I found the chart at the bottom...   Nov 2 2011, 07:08 AM
TargaToy   Man, am I glad I stopped to ask how to separate th...   Nov 6 2011, 04:33 PM
charliew   We use sugarsand to remove rust from metal that we...   Nov 7 2011, 10:43 AM
TargaToy   We use sugarsand to remove rust from metal that w...   Nov 8 2011, 01:41 PM
SirAndy   I blew through a tiny spot when blasting. Rust ha...   Nov 8 2011, 02:57 PM
- Lo-Fi Version Time is now: 16th March 2026 - 06:15 AM
