| bigkensteele |
Oct 29 2011, 09:08 PM
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States
I was checking out CL today, and I found a '71 2.2 not too far away. From the pics, it looks like the carbs are included, but the motor is disassembled. They are asking $1000. I have never rebuilt a motor, so I don't know what to look for other than the obvious (hole in the side of the case, blue bearings, bent rods or push rods, etc.)
Assuming that I could talk the guy down to $700 - 800, would this be a decent deal if it looks rebuildable? |
| BK911 |
Oct 31 2011, 02:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
A 2.2T is a nice engine. Scoots an early 911 along pretty well so should be even better in a 914. Put in 2.4 crank and rods and you have a VERY nice street engine with a nice flat torque curve. About the same compression as a 2.4S but more street friendly cams. Throw in some E cams and WOW!! I was under the impression you couldn't use the E or S cam with the T pistons without valve interference. Throw in the 2.4 crank and it would bring the piston even closer. (IMG:style_emoticons/default/confused24.gif) If the E cams work without machining the pistons I'll throw them in my 2.4T. (IMG:style_emoticons/default/driving.gif) Yes the pistons sometimes need to be machined. Sometimes the lower skirt needs some tweaking when putting 2.2 pistons on a 2.4 crank, and sometimes the valve pockets need massaging installing E cams with T pistons. Sometimes they will bolt right on. No matter what anybody says, you should always verify. 2.2 and 2.4 cranks will have the same deck heights. Material was removed off the "top" of the crank to give the extra stroke, so the pistons retracts further into the case. Not closer to the heads. |
bigkensteele Value of a 2.2 long block in pieces Oct 29 2011, 09:08 PM
Dr Evil With carbs, heck ya. The 2.2 is not equipped with ... Oct 29 2011, 10:23 PM
jmill If it has good pistons and cylinders it's a gr... Oct 30 2011, 07:26 AM
BK911 IMO $1000 is kinda steep. Unless the carbs a... Oct 30 2011, 08:55 AM
tscrihfield Hey ken,
I looked the same ad a couple days ago an... Oct 30 2011, 10:59 AM
sixnotfour pass ,,
But the carbs are worth something and the... Oct 30 2011, 12:48 PM
Dr Evil
pass ,,
But the carbs are worth something and th... Oct 30 2011, 01:36 PM
kg6dxn Buy the rebuilt turbo 6 engine on CL SF. Good pric... Oct 30 2011, 12:55 PM
jmill :WTF:
Did he use it as a saltwater boat anchor? ... Oct 30 2011, 03:00 PM
Cap'n Krusty IMO, the REAL question is how much the seller woul... Oct 30 2011, 03:59 PM
bigkensteele Thanks guys. Basically confirmed my suspicion. T... Oct 30 2011, 04:34 PM
avidfanjpl Junk is a kind assessment on that picture you post... Oct 31 2011, 01:58 AM
BK911 A 2.2T is a nice engine. Scoots an early 911 alon... Oct 31 2011, 08:48 AM
jmill
A 2.2T is a nice engine. Scoots an early 911 alo... Oct 31 2011, 11:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 05:08 AM |
