jasoncm |
Newbie ![]() Group: Members Posts: 2 Joined: 2-November 11 From: Dallas Member No.: 13,738 Region Association: None ![]() |
1974 1.8l that I have had for 5 years. Has always started right up and ran strong all the way to redline. Had a fender bender, and took it to body shop. Due to limited parts, it took 6 months! So I go to pick it up and the guy says "yeah....its not running so great." He says that he did not touch the engine bay, but I have no idea how it was treated or stored. (we had a heat wave in Dallas).
So now here is what happens: Starts easily with a flick of the key and idles fine. If you press on gas pedal the rpms will struggle up to 3000 and then, instantly it loses power and falls back down to idle or dies. No matter how much you feather the throttle, it always struggles to 3000 and then loses power. Still starts and idles fine, but not enough power to move. My thought was that maybe the body shop idiot was flooring the gas when he started and it backfired and damaged by air flow meter flap. I checked the flap and its movement seems fine. Any ideas? Again, the car ran great when I left it, now it has these symptoms. Fuel pressure regulator? Finally, does anyone know what pins on the Air flow meter I check for resistance? Any help is great! Jason |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
Looks like fuel delivery problem to me.
I would check the fuel pump. Probably it doesn't have enough flow to handle the fuel demand under acceleration. From what you describe, the AFM should be OK or else the engine would not rev-up. The ECU disregards the AFM reading at idle and WOT so the symptom you describe should not be related to the AFM. To test the fuel delivery use this: http://www.harborfreight.com/fuel-injectio...ster-92699.html |
Lo-Fi Version | Time is now: 15th July 2025 - 10:29 AM |
