1975 914 1st gear jumping out issue |
ndfrigi |
Nov 4 2011, 12:39 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hi 914's owner! I have 75' 2.0 914 and I'm having a problem with my 1st gear. It jump out upon releasing the clutch. I already replaced all the shift bushings but when I push down to 1st gear and while releasing my clutch, there you go it jump out or grinding from the gear happens. Any suggestions on how to fix it? thank you and God Bless!
Attached image(s) |
jimkelly |
Nov 4 2011, 01:05 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
your issue could be in here?
ignore that in pic - 1st gear of blocked off : ) your 1st gear dogteeth could be toast, or your 1st gear/reverse slider could be toast, or both could be toast. Attached image(s) |
ndfrigi |
Nov 4 2011, 01:09 PM
your issue could be in here? ignore that in pic - 1st gear of blocked off : ) your 1st gear dogteeth could be toast, or your 1st gear/reverse slider could be toast, or both could be toast. Is this image part of the transmission at the end part? where you will be able to see it when you removed the gear shifter? thanks! |
poorsche914 |
Nov 4 2011, 01:22 PM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Is your linkage adjusted correctly?
Could be not enough movement to engage first gear completely. Are you able to engage 3rd and 5th gears? (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 05:12 PM |
