Piston and Cyl. head coatings...Yes or No |
SpecialK |
Apr 29 2004, 07:18 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
I just read a pretty interesting article in the new Hot Rod mag that had to do with coatings for engine internals (pistons, cyl. heads...) from a place out in CA:
http://www.techlinecoatings.com/articles/a...ation_guide.htm They (Hot Rod) performed a test on a coated vs uncoated piston with acetylene torch, and the coated piston lasted three times longer than the uncoated piston (32 sec. vs 97 sec.) before melting a hole through it. They also recommended coating the inside of the cylinder head (particularly aluminum heads) and the face of the valves. All of these coatings can be applied at home, and cured in the oven (send the wife shopping...unless she's VERY understanding of your cause (IMG:style_emoticons/default/wink.gif) ) Any comments? |
Mark Henry |
Apr 30 2004, 12:35 PM
QUOTE(airsix @ Apr 30 2004, 09:41 AM) Here's a question: Are any OEM's using this technology? In one of their newsletters the company above said that Ford was testing/using some of their coatings. Berg offers the dry lube coating on their valve springs, since the mid-90's, they say it doubles the life. |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:43 AM |
