| malcolm2 |
Nov 4 2011, 05:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,752 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
Everytime I put something on, I realize I probably have to use sealant or gasket, or o-ring. What is the deal here. I found on the exploded view drawings that the distributor needs an o-ring. The picture on AA and Pelican matches the shape and size of the one I got in my gasket kit. But how does it install? Does it replace the brown hard ring or just slide on and up?
Thanks, ![]() |
| McMark |
Nov 4 2011, 05:27 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
B is dead, old garbage. Cut it off with a razor blade and toss it.
A will stretch over the shaft and slide up. A should have a D cross section, not an O. The flat part goes against the shaft, and the rounded portion faces out. |
| malcolm2 |
Nov 4 2011, 05:35 PM
B is dead, old garbage. Cut it off with a razor blade and toss it. A will stretch over the shaft and slide up. A should have a D cross section, not an O. The flat part goes against the shaft, and the rounded portion faces out. Yes D x-section is a much better description. Thanks for the input, I am breaking out the blade. |
malcolm2 Distributor O-ring Nov 4 2011, 05:23 PM
Vacca Rabite Replace.
The old one used to look like the new one... Nov 4 2011, 05:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th October 2026 - 02:39 AM |
