1975 914 1st gear jumping out issue |
ndfrigi |
Nov 4 2011, 12:39 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hi 914's owner! I have 75' 2.0 914 and I'm having a problem with my 1st gear. It jump out upon releasing the clutch. I already replaced all the shift bushings but when I push down to 1st gear and while releasing my clutch, there you go it jump out or grinding from the gear happens. Any suggestions on how to fix it? thank you and God Bless!
Attached image(s) |
ScottD914 |
Nov 4 2011, 07:01 PM
Member Group: Members Posts: 69 Joined: 27-December 07 From: New London, CT Member No.: 8,506 |
(IMG:style_emoticons/default/idea.gif) Hmm... I would suspect the linkage first. 1st is left and back (pulling your shift ball forward on the transmission).
Try shortening the linkage an 1/8" by loosening the clamp that grips the splined shaft under your shift lever. Re-tighten and give it a try. Worth a shot and better than tearing into the tranny. |
Richard Casto |
Nov 5 2011, 11:15 AM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
... and better than tearing into the tranny. (IMG:style_emoticons/default/confused24.gif) Nobody suggested pulling the transmission apart as step #1. Both Jim and I suggested testing to see if it is linkage/adjustment related first. Richard |
Lo-Fi Version | Time is now: 7th June 2024 - 04:02 PM |
