> Introduction and questions
ziggy
post Nov 14 2011, 08:39 PM
Howdy, first time caller, long time listener. I've got a '73 in yellow in the Austin, Texas area. PO did some mod stuff like the 911 master cyl and lowering the car. It has the requisite amount of rust and will be getting a whole lot of new metal when I pick up a mig machine. Also, I am probably insane - it is my daily driver ( I do have occasional access to a bug I work on) and after six months of working on it in a dirt driveway I finally have an old shed for a garage. The only real mod I have done is replacing the ignition switch. Those connections were all kinds of wonky when I pulled the old one so I put in a panel that separates the circuits with toggle switches and soldered the whole thing point-to-point. Master switch on left creates a hot bus, also mimics factory "off" or actual off, then radio, accessory, engine systems and then starter. Key is still needed to unlock steering wheel.
Now I have come across something strange. Alt light is on and gets very bright when I use blinkers or brake light. Headlights don't help, either. Idle is hunting like crazy and gauges seem a little erratic. Did the alternator diode test as per PP's article and neither B+ nor D+ tests killed the light, although they dropped the idle until the engine died. Problem started when I lost the alt belt and I replaced the belt and volt regulator at same time and was surprised to get no change. I want to get as much insight as possible before I tear that thing out. Any ideas?
ziggy
post Nov 15 2011, 12:17 AM
I like my version better than the factory's (no cluster of blades and an acc position) but I should cover up that hot rail. I have a feeling it is not the regulator since the D+ to DF short didn't kill the light. I am guessing I fried something in the alt, maybe these symptoms are the result of a busted winding trying to push two phase through the rectifier? I was hoping for a second opinion saying my alt was F'd in the A before going through that mess... I am an A&P student so I have a loose grasp of things but you just can't beat the hivemind of 914World! Thanks for the welcome, too!
ziggy   Introduction and questions   Nov 14 2011, 08:39 PM
ziggy   This one didn't come through the first time:   Nov 14 2011, 08:44 PM
clow   :wttc: Electrical is not my thing but you said ...   Nov 14 2011, 09:19 PM
ziggy   I replaced the regulator as I had been driving wit...   Nov 14 2011, 09:58 PM
clow   I am not fully sure about the regulator. Would it ...   Nov 14 2011, 10:19 PM
jcd914   My 5 second description of regulator function: Vol...   Nov 14 2011, 10:58 PM
ConeDodger   :wttc: Now buy some jackstands, and cuddle up to p...   Nov 14 2011, 11:19 PM
rick 918-S   :wttc: If I were you I would get a dash and igniti...   Nov 14 2011, 11:28 PM
ziggy   I like my version better than the factory's (n...   Nov 15 2011, 12:17 AM
Spoke   I have a feeling it is not the regulator since th...   Nov 15 2011, 04:25 PM
Dave_Darling   Check your fuses.... A blown one or a bad (dirty)...   Nov 15 2011, 01:29 AM
zymurgist   :wttc:   Nov 15 2011, 08:28 AM
nsr-jamie   Yes, check fuses first. I can see them in the pict...   Nov 15 2011, 08:45 AM
m170seeker   Ziggy, I am in Austin too.   Nov 15 2011, 11:29 AM
ziggy   The fuses all check out. I'll be updating them...   Nov 15 2011, 04:09 PM
Drums66   WELCOME :flag1:   Nov 15 2011, 05:19 PM
ziggy   Re-performed diode test and also tested battery an...   Nov 16 2011, 12:54 AM
Spoke   Re-performed diode test and also tested battery a...   Nov 16 2011, 01:32 AM
rwilner   I'm not much help with your troubleshooting, b...   Nov 16 2011, 06:35 AM
ziggy   Well, I put in a new alt and viola, problem solved...   Nov 20 2011, 04:30 PM
- Lo-Fi Version Time is now: 26th November 2026 - 03:37 AM
