> Timing Question, Got the dizzy out - crisis averted
bigkensteele
post Nov 15 2011, 09:11 PM
Major Member
Question: I can only see the timing mark on the impeller when the rotor is in the 2 and 4 position. When I had the engine on a stand, I could see it at 1. What gives?
Lead-up story: As some of you may have read, I finally got my car running on Sunday after a total reseal project. It is a 1.8 with L jet, and I installed a pertronix while the motor was out. I also replaced the dizzy O ring, but I never loosened the timing plate.
I was able to get it started on Sunday, and it ran pretty rough for a while and finally warmed up to a point where it was running OK at best.
Knowing that the timing was only in the ballpark, last night, I had the brilliant idea of loosening the plate and do a little tweaking. I went a bit to far and it died. (IMG:style_emoticons/default/barf.gif) So I moved it back to the approximate starting position, and it would not start.
That is when I decided to do it the right way, but I now my timing mark doesn't show when the rotor is on 1. (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/ar15.gif)
Valy
post Nov 16 2011, 03:25 AM
Calm down, its just the dizzy alignment. It may be that the gear jumped a tooth or more but that's not a big deal.
Put it back and visually check then the fan indicates TDC of cylinder 1. Now check the dizzy rotor and see what plug wire it points to. Adjust the dizzy a bit so it will point straight to one of the wires. That's your new #1 wire connection. Connect all the other wires in the ignition order and try to start it.
If it doesn't start, rotate the dizzy a bit and try again, till you find the spot. Then adjust the timing, even if the engine is still cold and re-adjust when the engine is hot.
bigkensteele   Timing Question   Nov 15 2011, 09:11 PM
underthetire   When you loosened the clamp, the dizzy probably po...   Nov 15 2011, 09:27 PM
bigkensteele   When you loosened the clamp, the dizzy probably p...   Nov 15 2011, 09:38 PM
underthetire   When you loosened the clamp, the dizzy probably ...   Nov 15 2011, 10:06 PM
Woody   Did the gear turn when you pulled the dizzy? Yes ...   Nov 15 2011, 09:34 PM
PancakePorsche   Hopefully you did not turn over engine (even by ha...   Nov 15 2011, 10:13 PM
Gint   :agree: If there is no downward pressure on the...   Nov 15 2011, 10:15 PM
bigkensteele   :agree: If there is no downward pressure on th...   Nov 15 2011, 10:50 PM
vsg914   :agree: If there is no downward pressure on t...   Nov 16 2011, 06:49 AM
Valy   Btw, your timing will not change when the engine ...   Nov 16 2011, 10:52 AM
bigkensteele   Btw, your timing will not change when the engine...   Nov 16 2011, 12:48 PM
SirAndy   Is there a better way to tell that doesn't inv...   Nov 16 2011, 01:17 PM
bigkensteele   Is there a better way to tell that doesn't in...   Nov 16 2011, 01:27 PM
SirAndy   [quote name='SirAndy' post='1572857' date='Nov 16 ...   Nov 16 2011, 01:33 PM
bigkensteele   [quote name='SirAndy' post='1572857' date='Nov 16...   Nov 16 2011, 02:29 PM
Valy   Calm down, its just the dizzy alignment. It may be...   Nov 16 2011, 03:25 AM
914rat   I just went over this same thing 2 weeks ago.Put a...   Nov 16 2011, 01:43 PM
vsg914   [quote name='vsg914' post='1572695' date='Nov 16...   Nov 16 2011, 02:36 PM
SirAndy   What ever happened to him? Last Active 5th Decem...   Nov 16 2011, 02:41 PM
Drums66   [quote name='bigkensteele' post='1572836' date='N...   Nov 17 2011, 06:34 PM
Valy   Haha. Only the idle speed changes. 3200 rmp is 3...   Nov 17 2011, 08:42 PM
bigkensteele   Now that I am looking at member numbers, have you ...   Nov 16 2011, 02:42 PM
vsg914   Now that I am looking at member numbers, have you...   Nov 16 2011, 02:46 PM
Drums66   :thumbsup: :bravo3d: (Valy)   Nov 18 2011, 04:49 PM
- Lo-Fi Version Time is now: 12th October 2026 - 09:03 AM
