> Timing Question, Got the dizzy out - crisis averted
bigkensteele
post Nov 15 2011, 09:11 PM
Major Member
Question: I can only see the timing mark on the impeller when the rotor is in the 2 and 4 position. When I had the engine on a stand, I could see it at 1. What gives?
Lead-up story: As some of you may have read, I finally got my car running on Sunday after a total reseal project. It is a 1.8 with L jet, and I installed a pertronix while the motor was out. I also replaced the dizzy O ring, but I never loosened the timing plate.
I was able to get it started on Sunday, and it ran pretty rough for a while and finally warmed up to a point where it was running OK at best.
Knowing that the timing was only in the ballpark, last night, I had the brilliant idea of loosening the plate and do a little tweaking. I went a bit to far and it died. (IMG:style_emoticons/default/barf.gif) So I moved it back to the approximate starting position, and it would not start.
That is when I decided to do it the right way, but I now my timing mark doesn't show when the rotor is on 1. (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/ar15.gif)
Gint
post Nov 15 2011, 10:15 PM
Mike Ginter
If there is no downward pressure on the dizzy and you turn the rotor (loosen the clamp and pull the dizzy up a millimeter or two), if the teeth aren't engaged on the drive gear, you'll know it right away because it will turn. If the teeth are engaged, the rotor won't turn. And if the teeth are riding up on top of the drive gear, turning the rotor should enable you to re-engage them.
If it still won't start, go back to #1 TDC and start over.
bigkensteele
post Nov 15 2011, 10:50 PM
Major Member
QUOTE(Gint @ Nov 15 2011, 08:15 PM) *
I followed Gint's advice and pulled the dizzy out a hair, and sure enough, the rotor turned freely.
I tried to re-index it back to TDC/rotor at the 1 position and push it back down. I could never get it to mate, so I decided to just pull the whole dizzy and take a look. Mind you, I have a new O ring on, so it is pretty tight. I got it out to the point where I can see the O ring, but it will NOT come out any further. Feels like the bottom of the drive is interfering with the case.
I just have this feeling that this is one of those "OH FUCH" moments. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
TheCabinetmaker
post Nov 16 2011, 06:49 AM
I drive my car everyday
QUOTE(bigkensteele @ Nov 15 2011, 10:50 PM) *
If there is no downward pressure on the dizzy and you turn the rotor (loosen the clamp and pull the dizzy up a millimeter or two), if the teeth aren't engaged on the drive gear, you'll know it right away because it will turn. Of the teeth are engaged, the rotor won't turn. And if the teeth are riding up on top of the drive gear, turning the rotor should enable you to re-engage them.
Ig it still won't start, go back to #1 TDC and start over.
The hole in the case is smooth and straight. If the diz pulled up past the ring it should pull out. Get the diz out and set it aside. Use a magnet to pull the drive gear. Set the engine to tdc #1. Using the magnet, place the drive gear back in with it oriented like in the haynes manual. If it doesnt want to go all the way down, place the car in 5th gear and gently rock the car till it drops in place. You can use the magnet to move the gear back and fourth. Make sure the washer is on the bottom of the drive gear. Use a little thick grease to hold it in place. Dont let it fall in the block. You can get it running like valy said, but you won't have the full range of motion. Hope this helps.
Btw, your timing will not change when the engine warms up.
Valy
post Nov 16 2011, 10:52 AM
QUOTE(vsg914 @ Nov 16 2011, 04:49 AM) *
That's correct but, the engine speed changes when it warms-up. Since the timing is checked at certain RPM, it should be checked on a warm engine, especially at idle.
bigkensteele
post Nov 16 2011, 12:48 PM
Major Member
QUOTE(Valy @ Nov 16 2011, 08:52 AM) *
I will time it cold to get it running well and then again when it warms up.
I got the dizzy out, by the way. The plate was hanging up on the tin, but it felt like the drive was hanging up in the shaft. I was very much relieved to see no brass shavings and the drive was indexed right where it is supposed to be. Now, I just need to pop the valve cover to make sure it is tdc for 1, rather than 2. Is there a better way to tell that doesn't involve spilling oil all over my heat exchanger?
post Nov 16 2011, 01:17 PM
Resident German
QUOTE(bigkensteele @ Nov 16 2011, 10:48 AM) *
Chop Sticks! (IMG:style_emoticons/default/laugh.gif)
bigkensteele
post Nov 16 2011, 01:27 PM
Major Member
QUOTE(SirAndy @ Nov 16 2011, 11:17 AM) *
I was actually thinking about pulling the #1 plug and probing for the piston top. A chop stick might be just the tool! (IMG:style_emoticons/default/idea.gif)
bigkensteele   Timing Question   Nov 15 2011, 09:11 PM
underthetire   When you loosened the clamp, the dizzy probably po...   Nov 15 2011, 09:27 PM
bigkensteele   When you loosened the clamp, the dizzy probably p...   Nov 15 2011, 09:38 PM
underthetire   When you loosened the clamp, the dizzy probably ...   Nov 15 2011, 10:06 PM
Woody   Did the gear turn when you pulled the dizzy? Yes ...   Nov 15 2011, 09:34 PM
PancakePorsche   Hopefully you did not turn over engine (even by ha...   Nov 15 2011, 10:13 PM
Gint   :agree: If there is no downward pressure on the...   Nov 15 2011, 10:15 PM
bigkensteele   :agree: If there is no downward pressure on th...   Nov 15 2011, 10:50 PM
vsg914   :agree: If there is no downward pressure on t...   Nov 16 2011, 06:49 AM
Valy   Btw, your timing will not change when the engine ...   Nov 16 2011, 10:52 AM
bigkensteele   Btw, your timing will not change when the engine...   Nov 16 2011, 12:48 PM
SirAndy   Is there a better way to tell that doesn't inv...   Nov 16 2011, 01:17 PM
bigkensteele   Is there a better way to tell that doesn't in...   Nov 16 2011, 01:27 PM
SirAndy   [quote name='SirAndy' post='1572857' date='Nov 16 ...   Nov 16 2011, 01:33 PM
bigkensteele   [quote name='SirAndy' post='1572857' date='Nov 16...   Nov 16 2011, 02:29 PM
Valy   Calm down, its just the dizzy alignment. It may be...   Nov 16 2011, 03:25 AM
914rat   I just went over this same thing 2 weeks ago.Put a...   Nov 16 2011, 01:43 PM
vsg914   [quote name='vsg914' post='1572695' date='Nov 16...   Nov 16 2011, 02:36 PM
SirAndy   What ever happened to him? Last Active 5th Decem...   Nov 16 2011, 02:41 PM
Drums66   [quote name='bigkensteele' post='1572836' date='N...   Nov 17 2011, 06:34 PM
Valy   Haha. Only the idle speed changes. 3200 rmp is 3...   Nov 17 2011, 08:42 PM
bigkensteele   Now that I am looking at member numbers, have you ...   Nov 16 2011, 02:42 PM
vsg914   Now that I am looking at member numbers, have you...   Nov 16 2011, 02:46 PM
Drums66   :thumbsup: :bravo3d: (Valy)   Nov 18 2011, 04:49 PM
- Lo-Fi Version Time is now: 12th October 2026 - 09:04 AM
