| bigkensteele |
Nov 15 2011, 09:11 PM
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States
Question: I can only see the timing mark on the impeller when the rotor is in the 2 and 4 position. When I had the engine on a stand, I could see it at 1. What gives?
Lead-up story: As some of you may have read, I finally got my car running on Sunday after a total reseal project. It is a 1.8 with L jet, and I installed a pertronix while the motor was out. I also replaced the dizzy O ring, but I never loosened the timing plate. I was able to get it started on Sunday, and it ran pretty rough for a while and finally warmed up to a point where it was running OK at best. Knowing that the timing was only in the ballpark, last night, I had the brilliant idea of loosening the plate and do a little tweaking. I went a bit to far and it died. (IMG:style_emoticons/default/barf.gif) So I moved it back to the approximate starting position, and it would not start. That is when I decided to do it the right way, but I now my timing mark doesn't show when the rotor is on 1. (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/ar15.gif) |
| TheCabinetmaker |
Nov 16 2011, 02:36 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Btw, your timing will not change when the engine warms up. That's correct but, the engine speed changes when it warms-up. Since the timing is checked at certain RPM, it should be checked on a warm engine, especially at idle. Haha. Only the idle speed changes. 3200 rmp is 3200 rpm. hot or cold. (IMG:style_emoticons/default/smile.gif) I will time it cold to get it running well and then again when it warms up. I got the dizzy out, by the way. The plate was hanging up on the tin, but it felt like the drive was hanging up in the shaft. I was very much relieved to see no brass shavings and the drive was indexed right where it is supposed to be. Now, I just need to pop the valve cover to make sure it is tdc for 1, rather than 2. Is there a better way to tell that doesn't involve spilling oil all over my heat exchanger? Is there a better way to tell that doesn't involve spilling oil all over my heat exchanger? Chop Sticks! (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/screwy.gif) What ever happened to him? |
bigkensteele Timing Question Nov 15 2011, 09:11 PM
underthetire When you loosened the clamp, the dizzy probably po... Nov 15 2011, 09:27 PM
bigkensteele
When you loosened the clamp, the dizzy probably p... Nov 15 2011, 09:38 PM
underthetire
When you loosened the clamp, the dizzy probably ... Nov 15 2011, 10:06 PM
Woody Did the gear turn when you pulled the dizzy? Yes ... Nov 15 2011, 09:34 PM
PancakePorsche Hopefully you did not turn over engine (even by ha... Nov 15 2011, 10:13 PM
Gint :agree:
If there is no downward pressure on the... Nov 15 2011, 10:15 PM
bigkensteele
:agree:
If there is no downward pressure on th... Nov 15 2011, 10:50 PM
vsg914
:agree:
If there is no downward pressure on t... Nov 16 2011, 06:49 AM
Valy
Btw, your timing will not change when the engine ... Nov 16 2011, 10:52 AM
bigkensteele
Btw, your timing will not change when the engine... Nov 16 2011, 12:48 PM
SirAndy Is there a better way to tell that doesn't inv... Nov 16 2011, 01:17 PM
bigkensteele
Is there a better way to tell that doesn't in... Nov 16 2011, 01:27 PM
SirAndy [quote name='SirAndy' post='1572857' date='Nov 16 ... Nov 16 2011, 01:33 PM
bigkensteele
[quote name='SirAndy' post='1572857' date='Nov 16... Nov 16 2011, 02:29 PM
Valy Calm down, its just the dizzy alignment. It may be... Nov 16 2011, 03:25 AM
914rat I just went over this same thing 2 weeks ago.Put a... Nov 16 2011, 01:43 PM
SirAndy What ever happened to him?
Last Active 5th Decem... Nov 16 2011, 02:41 PM
Drums66
[quote name='bigkensteele' post='1572836' date='N... Nov 17 2011, 06:34 PM
Valy
Haha. Only the idle speed changes. 3200 rmp is 3... Nov 17 2011, 08:42 PM
bigkensteele Now that I am looking at member numbers, have you ... Nov 16 2011, 02:42 PM
vsg914
Now that I am looking at member numbers, have you... Nov 16 2011, 02:46 PM
Drums66 :thumbsup: :bravo3d: (Valy) Nov 18 2011, 04:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th October 2026 - 09:04 AM |
