Help install Crane XR700 ignition, Honda guy at work on Porsche |
Jan 7 2003, 10:32 PM
Group: Posts: 0 Joined: -- Member No.: 0 |
Trying/was going to install it today. Where do I align the optical thingy thing to? I'm also guessing the round pizza thingy slots have to line up to the slot alingment thing is for the rotor. Yes, I'm too lazy to get the directions out and use the terms to make this easier. The directions that come with the kit are kinda broad and don't say much. Probably made for someone who knows what they are doing. (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/unsure.gif)
Dave_Darling |
Jan 14 2003, 12:51 PM
It ain't that hard. As I recall, the shutter wheel goes on the driveshaft easiest one way--the cam lobes on the shaft fit the "notched" areas on the ID of the shutter. I just pushed until the thing bottomed out.
Drop me a line some time and I can drive my 90 Si (Y-49, bay-bee!) over and give you a hand installing the Crane. If it doesn't have an LED, then there's some monkeying around to do with the ignition on (move the pickup until you get a "ZAP" from the center coil wire taped near ground). The general idea is to get it close when the rotor is pointing at the pickup for the #1 cylinder. Then you tighten it all down and put it all together again, and set the timing for good. --DD |
Lo-Fi Version | Time is now: 8th June 2024 - 02:58 AM |
