| orange914 |
Nov 19 2011, 01:18 PM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
O.K. so disc brake performance has so many different aspects. Add your experiances and wisdom to the question below
Starting with the solid vrs. vented... venting, heat, weight, stopping performance, off gasing, strength My main question is what exactly are the performance pro's & cons of each: A] slotted B] dimpled C] cross drilled Summit refered to this and it made my wonder (IMG:style_emoticons/default/confused24.gif) |
| underthetire |
Nov 20 2011, 12:46 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Motorcycles use steel rotors, not cast iron or sintered steel, so they can get away with drilling, or through slotting. I agree with the no drilling of stock rotors, but slotting can be done on both manual or cnc machines almost equally easilily. The spiral slotting is a whole lot easier on cnc. I do have a guy local that can do them in his garage, he has a decent cnc bed mill in his garage if you need it done.
orange914 rotor disc performance questions Nov 19 2011, 01:18 PM
tscrihfield
O.K. so disc brake performance has so many differ... Nov 19 2011, 04:27 PM
ArtechnikA
Slotted, dimpled and cross drilled rotors are all... Nov 20 2011, 07:48 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 01:32 AM |
