> Optional Clean Heat, my attemp for gas heat
sixnotfour
post Nov 20 2011, 03:58 PM
I live in the PNW and wanted to try a different approach.
1. clean no motor air
2. Instant with out motor running.
3. not gasoline.
Reading about auxi. heaters for years, I always wanted a Wabasto Esenbacher OR
or similar, with the no idle laws in place they became much more affordable, but run on diesel, yes they make gasoline (not what I wanted)
Price new 1100-2000
Searching around I found a propane fired unit Propex hs200, $700
more the teener price range.
I did consider the deisel wabasto ,but I dont like the smell of deisel and propane has the nasty odor for saftey.
I was still not sure how the thing would perform so I did a quicky install.
I only had to drill 2 - 1 inch holes and various screw hole , not bad.
As I said this is the quicky install for testing.............so far so good.
here is the unit;
http://westyventures.com/propex.html
sixnotfour
post Nov 20 2011, 04:21 PM
So far for air circulation I have capped the long heat tubes and cut off the hose flush behind the speaker grill, So the defrost air is being pulled from inside the cabin.
Works OK, but needed a better push = Fan.
So I got a couple of Carrera footwell blowers and found they fit quite well.
The hoses do not hook up well though.
sixnotfour   Optional Clean Heat   Nov 20 2011, 03:58 PM
sixnotfour   Current condition , and 10 minutes of running, una...   Nov 20 2011, 04:01 PM
sixnotfour   Here is the location I chose. passenger footwell. ...   Nov 20 2011, 04:05 PM
sixnotfour   Intake and exhaust through the floor and back. Ag...   Nov 20 2011, 04:07 PM
mepstein   Nice!   Nov 20 2011, 04:08 PM
sixnotfour   The cover aluminum, As you can see thats as far as...   Nov 20 2011, 04:12 PM
Tom   Jeff, That really looks like a good option for...   Nov 20 2011, 04:13 PM
sixnotfour   OK the fuel supply, 11lb 2.5 gal propane tank ...   Nov 20 2011, 04:15 PM
sixnotfour   So far for air circulation I have capped the long ...   Nov 20 2011, 04:21 PM
sixnotfour   I have these fabbed up and the hose will be a stra...   Nov 20 2011, 04:23 PM
sixnotfour   BTW the foot well blowers are an awesome addition ...   Nov 20 2011, 04:24 PM
a914dude   Have you considered using the camper sized bottles...   Nov 20 2011, 04:32 PM
smontanaro   Very interesting. I don't really have an appl...   Nov 20 2011, 04:34 PM
sixnotfour   Skip, I really wanted to mount it in the rear tr...   Nov 20 2011, 04:45 PM
a914dude   Can you post PDF copies of the idiot book?   Nov 20 2011, 04:48 PM
sixnotfour   I went to a get together and my 914 was great=warm...   Nov 20 2011, 04:51 PM
r_towle   You had my interest up until I saw the bomb in the...   Nov 20 2011, 06:54 PM
sixnotfour   ever try to blow one up ? Be COLD or use diesel ...   Nov 20 2011, 08:54 PM
r_towle   Not sure how cold it gets where you live, but my h...   Nov 20 2011, 09:00 PM
sixnotfour   WTF does that mean ? I can go out start the heat...   Nov 20 2011, 09:04 PM
damesandhotrods   The angry burning orb appeared in the sky today, s...   Nov 20 2011, 09:09 PM
70 914   I saw it in action , pretty f'n kool!   Nov 20 2011, 10:17 PM
sixnotfour   I did the propane 1- the price, 2 - I knew I cou...   Nov 21 2011, 06:05 AM
Mark Henry   The the only concern I have is I think legally (II...   Nov 21 2011, 06:55 AM
BarberDave   :trophy: WOW, I agree a bomb in the front tr...   Nov 21 2011, 07:30 AM
Bartlett 914   :trophy: WOW, I agree a bomb in the front t...   Nov 21 2011, 08:28 AM
Dr Evil   Man, I just did a youtube search for "propane...   Nov 21 2011, 10:04 AM
Gint   You'll shoot yer eye out kid!   Nov 21 2011, 06:58 PM
sixnotfour   how long does it take to boil water ?   Nov 21 2011, 08:14 PM
Dr Evil   No need to boil. I am hoping to circulate at speed...   Nov 21 2011, 09:05 PM
sixnotfour   True , but I removed the 2-3 inch floor plugs an...   Nov 22 2011, 02:01 PM
Dr Evil   True , but I removed the 2-3 inch floor plugs a...   Nov 22 2011, 03:18 PM
r_towle   Motorhome tanks are required to be out in the open...   Nov 22 2011, 02:35 PM
SLITS   Damn, you guys leave poor Jeff alone. He already ...   Nov 22 2011, 03:03 PM
sixnotfour   I will try one of the small camp bottles and see h...   Nov 22 2011, 03:45 PM
bandjoey   With the floor open, a small low pressure area mig...   Nov 22 2011, 07:54 PM
GeorgeRud   For motorhomes, the propane compartment must have ...   Nov 22 2011, 08:27 PM
Bartlett 914   A gas leak will be a problem regardless of where t...   Nov 23 2011, 10:24 AM
Jake Raby   Just finishing an Espar B1LC gasoline heater in my...   Nov 23 2011, 10:44 AM
sixnotfour   jake good stuff, The bus guys use em all and love ...   Nov 23 2011, 11:34 AM
Jake Raby   Just hope you don't have any frontal collision...   Nov 23 2011, 11:58 AM
Speedster Mike   Just hope you don't have any frontal collisio...   Nov 23 2011, 12:07 PM
sixnotfour   I wonder how it compares to the propex, noise wis...   Nov 23 2011, 03:49 PM
sixnotfour   a tire and wheel surrounding , is the best prote...   Nov 25 2011, 11:34 AM
PeeGreen 914   a tire and wheel surrounding , is the best prot...   Nov 25 2011, 04:27 PM
Spoke   Nice ingenuity. Standard heat in a 914 is marginal...   Nov 25 2011, 01:46 PM
Tom   Propane tanks are much stronger than most posters ...   Nov 25 2011, 02:38 PM
rfuerst911sc   In my opinion you should look into mounting smalle...   Nov 25 2011, 04:05 PM
Gint   Modern Marvels on the History channel featured thi...   Nov 28 2011, 10:23 PM
iamchappy   I bumped into this guys solution http://www.atomi...   Dec 1 2011, 11:24 AM
Mark Henry   At the risk of being a dick.....Fuch it I can live...   Dec 3 2011, 02:04 PM
02loftsmoor   I work with CNG and LNG fuel trucks coast to coast...   Dec 3 2011, 02:36 PM
Mark Henry   I work with CNG and LNG fuel trucks coast to coas...   Dec 3 2011, 02:47 PM
02loftsmoor   then someone removed the pop off valve, aka human...   Dec 3 2011, 02:54 PM
Mark Henry   then someone removed the pop off valve, aka huma...   Dec 3 2011, 03:25 PM
sixnotfour   :welder:   Dec 3 2011, 03:03 PM
sixnotfour   A house here in WA. just blew up about the same re...   Dec 3 2011, 03:08 PM
sixnotfour   Your not a Dick , Just not a believer   Dec 3 2011, 03:12 PM
Mark Henry   Why I said "Transferring truck to truck...   Dec 3 2011, 03:41 PM
02loftsmoor   bottom line have respect for any pressurized gas, ...   Dec 3 2011, 03:48 PM
Dr Evil   Its a fire tetrahedron now: Fuel - heat - oxygen -...   Dec 3 2011, 05:40 PM
sixnotfour   Mark ,Propane tanks have evolved greatly since the...   Dec 3 2011, 05:52 PM
- Lo-Fi Version Time is now: 18th November 2025 - 05:41 AM
