| sixnotfour |
Nov 20 2011, 03:58 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,031 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains
I live in the PNW and wanted to try a different approach.
1. clean no motor air 2. Instant with out motor running. 3. not gasoline. Reading about auxi. heaters for years, I always wanted a Wabasto Esenbacher OR or similar, with the no idle laws in place they became much more affordable, but run on diesel, yes they make gasoline (not what I wanted) Price new 1100-2000 Searching around I found a propane fired unit Propex hs200, $700 more the teener price range. I did consider the deisel wabasto ,but I dont like the smell of deisel and propane has the nasty odor for saftey. I was still not sure how the thing would perform so I did a quicky install. I only had to drill 2 - 1 inch holes and various screw hole , not bad. As I said this is the quicky install for testing.............so far so good. here is the unit; http://westyventures.com/propex.html Attached image(s)
| bandjoey |
Nov 22 2011, 07:54 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
With the floor open, a small low pressure area might build and the gas would enter the cabin????? just a thought.
sixnotfour Optional Clean Heat Nov 20 2011, 03:58 PM
sixnotfour Current condition , and 10 minutes of running, una... Nov 20 2011, 04:01 PM
sixnotfour Here is the location I chose. passenger footwell. ... Nov 20 2011, 04:05 PM
sixnotfour Intake and exhaust through the floor and back.
Ag... Nov 20 2011, 04:07 PM
mepstein Nice! Nov 20 2011, 04:08 PM
sixnotfour The cover aluminum, As you can see thats as far as... Nov 20 2011, 04:12 PM
Tom Jeff,
That really looks like a good option for... Nov 20 2011, 04:13 PM
sixnotfour OK the fuel supply, 11lb 2.5 gal propane tank ... Nov 20 2011, 04:15 PM
sixnotfour So far for air circulation I have capped the long ... Nov 20 2011, 04:21 PM
sixnotfour I have these fabbed up and the hose will be a stra... Nov 20 2011, 04:23 PM
sixnotfour BTW the foot well blowers are an awesome addition ... Nov 20 2011, 04:24 PM
a914dude Have you considered using the camper sized bottles... Nov 20 2011, 04:32 PM
smontanaro Very interesting. I don't really have an appl... Nov 20 2011, 04:34 PM
sixnotfour
Skip, I really wanted to mount it in the rear tr... Nov 20 2011, 04:45 PM
a914dude Can you post PDF copies of the idiot book? Nov 20 2011, 04:48 PM
sixnotfour I went to a get together and my 914 was great=warm... Nov 20 2011, 04:51 PM
r_towle You had my interest up until I saw the bomb in the... Nov 20 2011, 06:54 PM
sixnotfour
ever try to blow one up ? Be COLD or use diesel ... Nov 20 2011, 08:54 PM
r_towle Not sure how cold it gets where you live, but my h... Nov 20 2011, 09:00 PM
sixnotfour
WTF does that mean ? I can go out start the heat... Nov 20 2011, 09:04 PM
damesandhotrods The angry burning orb appeared in the sky today, s... Nov 20 2011, 09:09 PM
70 914 I saw it in action , pretty f'n kool! Nov 20 2011, 10:17 PM
sixnotfour I did the propane 1- the price, 2 - I knew I cou... Nov 21 2011, 06:05 AM
Mark Henry The the only concern I have is I think legally (II... Nov 21 2011, 06:55 AM
BarberDave :trophy:
WOW, I agree a bomb in the front tr... Nov 21 2011, 07:30 AM
Bartlett 914
:trophy:
WOW, I agree a bomb in the front t... Nov 21 2011, 08:28 AM
Dr Evil Man, I just did a youtube search for "propane... Nov 21 2011, 10:04 AM
Gint You'll shoot yer eye out kid! Nov 21 2011, 06:58 PM
sixnotfour
how long does it take to boil water ? Nov 21 2011, 08:14 PM
Dr Evil No need to boil. I am hoping to circulate at speed... Nov 21 2011, 09:05 PM
sixnotfour
True , but I removed the 2-3 inch floor plugs an... Nov 22 2011, 02:01 PM
Dr Evil
True , but I removed the 2-3 inch floor plugs a... Nov 22 2011, 03:18 PM
r_towle Motorhome tanks are required to be out in the open... Nov 22 2011, 02:35 PM
SLITS Damn, you guys leave poor Jeff alone. He already ... Nov 22 2011, 03:03 PM
sixnotfour I will try one of the small camp bottles and see h... Nov 22 2011, 03:45 PM
GeorgeRud For motorhomes, the propane compartment must have ... Nov 22 2011, 08:27 PM
Bartlett 914 A gas leak will be a problem regardless of where t... Nov 23 2011, 10:24 AM
Jake Raby Just finishing an Espar B1LC gasoline heater in my... Nov 23 2011, 10:44 AM
sixnotfour jake good stuff, The bus guys use em all and love ... Nov 23 2011, 11:34 AM
Jake Raby Just hope you don't have any frontal collision... Nov 23 2011, 11:58 AM
Speedster Mike
Just hope you don't have any frontal collisio... Nov 23 2011, 12:07 PM
sixnotfour I wonder how it compares to the propex, noise wis... Nov 23 2011, 03:49 PM
sixnotfour
a tire and wheel surrounding , is the best prote... Nov 25 2011, 11:34 AM
PeeGreen 914
a tire and wheel surrounding , is the best prot... Nov 25 2011, 04:27 PM
Spoke Nice ingenuity. Standard heat in a 914 is marginal... Nov 25 2011, 01:46 PM
Tom Propane tanks are much stronger than most posters ... Nov 25 2011, 02:38 PM
rfuerst911sc In my opinion you should look into mounting smalle... Nov 25 2011, 04:05 PM
Gint Modern Marvels on the History channel featured thi... Nov 28 2011, 10:23 PM
iamchappy I bumped into this guys solution
http://www.atomi... Dec 1 2011, 11:24 AM
Mark Henry At the risk of being a dick.....Fuch it I can live... Dec 3 2011, 02:04 PM
02loftsmoor I work with CNG and LNG fuel trucks coast to coast... Dec 3 2011, 02:36 PM
Mark Henry
I work with CNG and LNG fuel trucks coast to coas... Dec 3 2011, 02:47 PM
02loftsmoor then someone removed the pop off valve, aka human... Dec 3 2011, 02:54 PM
Mark Henry
then someone removed the pop off valve, aka huma... Dec 3 2011, 03:25 PM
sixnotfour :welder: Dec 3 2011, 03:03 PM
sixnotfour A house here in WA. just blew up about the same re... Dec 3 2011, 03:08 PM
sixnotfour
Your not a Dick , Just not a believer Dec 3 2011, 03:12 PM
Mark Henry Why I said "Transferring truck to truck... Dec 3 2011, 03:41 PM
02loftsmoor bottom line have respect for any pressurized gas, ... Dec 3 2011, 03:48 PM
Dr Evil Its a fire tetrahedron now: Fuel - heat - oxygen -... Dec 3 2011, 05:40 PM
sixnotfour Mark ,Propane tanks have evolved greatly since the... Dec 3 2011, 05:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th November 2025 - 05:39 AM |
