> Fuel pump shorting out, help me find the short
pgeorgeson
post Nov 23 2011, 04:24 PM
The good news: I got the fuel pump working.
The bad news: It keeps blowing the fuse.
I am fairly certain that the pump not the problem. I think I have a short.
I have checked the fuse panel and cleaned up all the contacts there. The main harness looks fine as it goes into the tunnel and comes out of the tunnel in the engine compartment. I have checked the wires coming off the main harness to the pump. The plug to the pump looks fine. From what I can see of it, the wires also look good behind the dash. I am thinking the short may be in the tunnel.
Any specific ideas of where I should look for a short that I haven't looked for already?
If it is the tunnel, is there any way to check for a short in there other than pulling the entire harness out?
ejm
post Nov 23 2011, 04:55 PM
I can see the light at the end of the tunnel
Assuming you are running stock fuel injection I would check the wiring to the auxiliary air regulator which is also powered by the fuel pump circuit. If the wiring looks good unplug the AAR and see if the short goes away.
A stock '74 would have the pump in the back and none of the associated wiring goes thru the tunnel. If the pump has been moved up front anything is possible.
- Lo-Fi Version Time is now: 17th April 2026 - 02:04 AM
