> Fuel pump shorting out, help me find the short
pgeorgeson
post Nov 23 2011, 04:24 PM
The good news: I got the fuel pump working.
The bad news: It keeps blowing the fuse.
I am fairly certain that the pump not the problem. I think I have a short.
I have checked the fuse panel and cleaned up all the contacts there. The main harness looks fine as it goes into the tunnel and comes out of the tunnel in the engine compartment. I have checked the wires coming off the main harness to the pump. The plug to the pump looks fine. From what I can see of it, the wires also look good behind the dash. I am thinking the short may be in the tunnel.
Any specific ideas of where I should look for a short that I haven't looked for already?
If it is the tunnel, is there any way to check for a short in there other than pulling the entire harness out?
ejm
post Nov 23 2011, 04:55 PM
I can see the light at the end of the tunnel
Assuming you are running stock fuel injection I would check the wiring to the auxiliary air regulator which is also powered by the fuel pump circuit. If the wiring looks good unplug the AAR and see if the short goes away.
A stock '74 would have the pump in the back and none of the associated wiring goes thru the tunnel. If the pump has been moved up front anything is possible.
pgeorgeson
post Nov 23 2011, 05:12 PM
QUOTE(ejm @ Nov 23 2011, 03:55 PM) *
The pump is in it stock location in the right front of the engine compartment.
Please excuse my ignorance (and be gentle with me). From what I can see, the wires for the pump are joined with the main harness that plugs into the front of the fuse panel (on the left side of the front of the engine compartment). That harness then runs down and along the bottom of the front left side of the engine compartment, then appears (although it is difficult to tell) to go into a hole in the bottom front middle of the engine compartment and into the tunnel. It appears, then, that the harness then also comes out of that same hole and then goes around to the other side (right side) of the engine compartment.
I was assuming that because the fuel pump is switched to the ignition, then the fuel pump wiring ran from the fuse box, through the tunnel, up to the dash, to the ignition, and then back through the tunnel to the engine compartment and to the pump.
Am i wrong? Does all the wiring for the fuel pump just run from the left side of the engine compartment (from the fuse box) across the bottom to the right side of the engine compartment (where the pump is)?
(I would note that all the wiring that I can see in the engine compartment looks fine).
In any event, I will check the Aux. Air Regulator.
- Lo-Fi Version Time is now: 17th April 2026 - 02:04 AM
