> another stupid electrical question, what is right/normal/bad
timofly
post Nov 24 2011, 11:11 AM
74 2.0 FI with console voltage gauge, shows 13+ volts running with no lights on. Turning on parking lights or stepping on the brake drops it to about 12.2. Turning on headlights drops it further to just below 12. Fog lights have no effect (they are working) but turn signals will drop it to 11 with headlights on. Brakes with headlights on also drops it to 11 volts. Battery (Red Top) shows 12.5 volts with engine off after a good run.
Before someone says: "Did you read the threads here on this?" Yes, I have, and the same conditions draw responses ranging from "that's normal" to "your regulator/aternator/phisoginator is about to fail", so they leave me right where I started.
I have cleaned the grounds in the front fenders right by the headlight motors, with no effect.
So, three dumb questions:
1. what's the best way to check the voltage being sent to the battery
2. where is the ground connection to the body for the tailights,
3. am I worrying about nothing?
Happy Thanksgiving to all and thanks for any advice.
Mike Bellis
post Nov 24 2011, 11:21 AM
Resident Electrician
Check the actuall battery voltage at the battery.
The tail light ground is on the side wall below the relay board.
The stock voltage gauge is almost useless.
timofly
post Nov 24 2011, 11:26 AM
QUOTE(kg6dxn @ Nov 24 2011, 12:21 PM) *
I should have clarified that the battery voltage of 12.5 was measured at the battery, not taken from the gauge.
Mike Bellis
post Nov 24 2011, 11:38 AM
QUOTE(timofly @ Nov 24 2011, 10:26 AM) *
Each cell of the battery is about 2.1 volts. A car battery has 6 cells. Your voltage at 12.5V is acceptable. Most alternators/regulators do not produce charging voltage below 1500rpm. At idle with all your loads turned on, you should see less than 12.5V. At >2000rpm you should see about 13.5-14.5V at the battery. The stock volt gauge is wired to see all the loads in the car. That's why you can turn on the blinkers and watch it bounce. If you want the stock gauge to be more "accurate", you would need dedicated power and ground wires from the battery 12gauge or larger.
- Lo-Fi Version Time is now: 15th March 2026 - 05:06 AM
