| sixnotfour |
Nov 20 2011, 03:58 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,031 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains
I live in the PNW and wanted to try a different approach.
1. clean no motor air 2. Instant with out motor running. 3. not gasoline. Reading about auxi. heaters for years, I always wanted a Wabasto Esenbacher OR or similar, with the no idle laws in place they became much more affordable, but run on diesel, yes they make gasoline (not what I wanted) Price new 1100-2000 Searching around I found a propane fired unit Propex hs200, $700 more the teener price range. I did consider the deisel wabasto ,but I dont like the smell of deisel and propane has the nasty odor for saftey. I was still not sure how the thing would perform so I did a quicky install. I only had to drill 2 - 1 inch holes and various screw hole , not bad. As I said this is the quicky install for testing.............so far so good. here is the unit; http://westyventures.com/propex.html Attached image(s)
| Tom |
Nov 25 2011, 02:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Propane tanks are much stronger than most posters seem to be aware of. Smaller ones even stronger. Just google propane tank strength tests.
Jeff, I would ride with you in your warm 914. The only concern I can really see with this is the valve area. Maybe some protection there would be a good idea. If the car is in a collision that is bad enough to cause rupture of the tank, anyone inside will have other issues than burning propane. And the gas tank would probably be compromised also. I don't think it would be that hard to devise some electronic system of tank pressure monitoring and propane use. IE: is the pressure remaining steady, OK no alarm light. If the pressure is changing and is the heater on. If both yes, then no alarm light. Heater not on and pressure changing, Alarm light. Tom |
sixnotfour Optional Clean Heat Nov 20 2011, 03:58 PM
sixnotfour Current condition , and 10 minutes of running, una... Nov 20 2011, 04:01 PM
sixnotfour Here is the location I chose. passenger footwell. ... Nov 20 2011, 04:05 PM
sixnotfour Intake and exhaust through the floor and back.
Ag... Nov 20 2011, 04:07 PM
mepstein Nice! Nov 20 2011, 04:08 PM
sixnotfour The cover aluminum, As you can see thats as far as... Nov 20 2011, 04:12 PM
Tom Jeff,
That really looks like a good option for... Nov 20 2011, 04:13 PM
sixnotfour OK the fuel supply, 11lb 2.5 gal propane tank ... Nov 20 2011, 04:15 PM
sixnotfour So far for air circulation I have capped the long ... Nov 20 2011, 04:21 PM
sixnotfour I have these fabbed up and the hose will be a stra... Nov 20 2011, 04:23 PM
sixnotfour BTW the foot well blowers are an awesome addition ... Nov 20 2011, 04:24 PM
a914dude Have you considered using the camper sized bottles... Nov 20 2011, 04:32 PM
smontanaro Very interesting. I don't really have an appl... Nov 20 2011, 04:34 PM
sixnotfour
Skip, I really wanted to mount it in the rear tr... Nov 20 2011, 04:45 PM
a914dude Can you post PDF copies of the idiot book? Nov 20 2011, 04:48 PM
sixnotfour I went to a get together and my 914 was great=warm... Nov 20 2011, 04:51 PM
r_towle You had my interest up until I saw the bomb in the... Nov 20 2011, 06:54 PM
sixnotfour
ever try to blow one up ? Be COLD or use diesel ... Nov 20 2011, 08:54 PM
r_towle Not sure how cold it gets where you live, but my h... Nov 20 2011, 09:00 PM
sixnotfour
WTF does that mean ? I can go out start the heat... Nov 20 2011, 09:04 PM
damesandhotrods The angry burning orb appeared in the sky today, s... Nov 20 2011, 09:09 PM
70 914 I saw it in action , pretty f'n kool! Nov 20 2011, 10:17 PM
sixnotfour I did the propane 1- the price, 2 - I knew I cou... Nov 21 2011, 06:05 AM
Mark Henry The the only concern I have is I think legally (II... Nov 21 2011, 06:55 AM
BarberDave :trophy:
WOW, I agree a bomb in the front tr... Nov 21 2011, 07:30 AM
Bartlett 914
:trophy:
WOW, I agree a bomb in the front t... Nov 21 2011, 08:28 AM
Dr Evil Man, I just did a youtube search for "propane... Nov 21 2011, 10:04 AM
Gint You'll shoot yer eye out kid! Nov 21 2011, 06:58 PM
sixnotfour
how long does it take to boil water ? Nov 21 2011, 08:14 PM
Dr Evil No need to boil. I am hoping to circulate at speed... Nov 21 2011, 09:05 PM
sixnotfour
True , but I removed the 2-3 inch floor plugs an... Nov 22 2011, 02:01 PM
Dr Evil
True , but I removed the 2-3 inch floor plugs a... Nov 22 2011, 03:18 PM
r_towle Motorhome tanks are required to be out in the open... Nov 22 2011, 02:35 PM
SLITS Damn, you guys leave poor Jeff alone. He already ... Nov 22 2011, 03:03 PM
sixnotfour I will try one of the small camp bottles and see h... Nov 22 2011, 03:45 PM
bandjoey With the floor open, a small low pressure area mig... Nov 22 2011, 07:54 PM
GeorgeRud For motorhomes, the propane compartment must have ... Nov 22 2011, 08:27 PM
Bartlett 914 A gas leak will be a problem regardless of where t... Nov 23 2011, 10:24 AM
Jake Raby Just finishing an Espar B1LC gasoline heater in my... Nov 23 2011, 10:44 AM
sixnotfour jake good stuff, The bus guys use em all and love ... Nov 23 2011, 11:34 AM
Jake Raby Just hope you don't have any frontal collision... Nov 23 2011, 11:58 AM
Speedster Mike
Just hope you don't have any frontal collisio... Nov 23 2011, 12:07 PM
sixnotfour I wonder how it compares to the propex, noise wis... Nov 23 2011, 03:49 PM
sixnotfour
a tire and wheel surrounding , is the best prote... Nov 25 2011, 11:34 AM
PeeGreen 914
a tire and wheel surrounding , is the best prot... Nov 25 2011, 04:27 PM
Spoke Nice ingenuity. Standard heat in a 914 is marginal... Nov 25 2011, 01:46 PM
rfuerst911sc In my opinion you should look into mounting smalle... Nov 25 2011, 04:05 PM
Gint Modern Marvels on the History channel featured thi... Nov 28 2011, 10:23 PM
iamchappy I bumped into this guys solution
http://www.atomi... Dec 1 2011, 11:24 AM
Mark Henry At the risk of being a dick.....Fuch it I can live... Dec 3 2011, 02:04 PM
02loftsmoor I work with CNG and LNG fuel trucks coast to coast... Dec 3 2011, 02:36 PM
Mark Henry
I work with CNG and LNG fuel trucks coast to coas... Dec 3 2011, 02:47 PM
02loftsmoor then someone removed the pop off valve, aka human... Dec 3 2011, 02:54 PM
Mark Henry
then someone removed the pop off valve, aka huma... Dec 3 2011, 03:25 PM
sixnotfour :welder: Dec 3 2011, 03:03 PM
sixnotfour A house here in WA. just blew up about the same re... Dec 3 2011, 03:08 PM
sixnotfour
Your not a Dick , Just not a believer Dec 3 2011, 03:12 PM
Mark Henry Why I said "Transferring truck to truck... Dec 3 2011, 03:41 PM
02loftsmoor bottom line have respect for any pressurized gas, ... Dec 3 2011, 03:48 PM
Dr Evil Its a fire tetrahedron now: Fuel - heat - oxygen -... Dec 3 2011, 05:40 PM
sixnotfour Mark ,Propane tanks have evolved greatly since the... Dec 3 2011, 05:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th November 2025 - 05:42 AM |
