| malcolm2 |
Nov 28 2011, 12:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
I am to the point on my rebuild that I need to make a decision. (IMG:style_emoticons/default/confused24.gif)
I am sure that this type of discussion can become very technical and fill volumes of books. I am not asking for that. I am the kind of person that wants to know "why" a certain cam needs a certain CR. In order to make the best decision, I need answers. Or if it is a huge secret, that is fine too. I can go blindly along with the crowd. Maybe it's really what. Has anyone experienced What an engine will do, or what will I see or feel if my cam mfg recommends 8.0:1 CR and my normal state (no shims) is 8.35:1 CR? To get to just about 8, I have calculated that I need about 2mm of deck height. I am currently sitting at 1.62mm average DH with a variance between cylinders of 0.15mm. So I need two 0.4mm shims and two 0.5mm shims and I will be dead nuts on 8:1. (IMG:style_emoticons/default/stirthepot.gif) So the mfgr's value can be reached (if I can round up the shims), but I am curious to know how differently the engine will function if I go shim-less or even only get half way, maybe 8.2:1. (IMG:style_emoticons/default/WTF.gif) |
| r_towle |
Nov 28 2011, 02:46 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Jake Raby
or European Motorworks rich |
malcolm2 Hitting the exact Compression Ratio Nov 28 2011, 12:42 PM
McMark Don't mix different height shims on the same s... Nov 28 2011, 12:52 PM
malcolm2
Don't mix different height shims on the same ... Nov 28 2011, 02:46 PM
mark21742 Most cam manufacturers give you minimum compressio... Nov 28 2011, 01:08 PM
r_towle Compression ratio and camshaft selection go hand i... Nov 28 2011, 01:17 PM
malcolm2
Compression ratio and camshaft selection go hand ... Nov 28 2011, 02:43 PM
Marty Yeoman
You have other options if you do not want to shi... Nov 28 2011, 02:51 PM
malcolm2
You have other options if you do not want to sh... Nov 28 2011, 03:01 PM
r_towle more deck height is either more shims or deeper ch... Nov 28 2011, 03:07 PM
malcolm2
more deck height is either more shims or deeper c... Nov 28 2011, 03:14 PM
r_towle if you had the case "checked over" they ... Nov 28 2011, 03:21 PM
Jake Raby It is common to achieve different true deck height... Nov 28 2011, 03:26 PM
malcolm2
It is common to achieve different true deck heigh... Nov 28 2011, 03:49 PM
Jake Raby
I am trying really hard to lessen that expectati... Nov 28 2011, 04:13 PM
malcolm2
I am trying really hard to lessen that expectat... Nov 28 2011, 07:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th August 2026 - 06:46 PM |
