New KB Piston Question, My new set came with two rings- why? |
tornik550 |
Dec 3 2011, 08:11 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I just got a new KB 96mm piston (I had to replace one damaged piston). The new piston came with two rings that are just a little thicker than the oil rings- they have a dimple on one side. The grove in the piston where the oil rings sit is wider than my older set. The new piston also doesn't have the oil ring locating pin.
What are the rings that came with the piston for? |
Jake Raby |
Dec 3 2011, 09:53 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Align the bump down and place in the wrist pin bore relief. This locks the support rail from rotating during operation.
Read the instructions. The pistons changed in late 2009. I hope you kept the box the rings came in and know which slots they came from, else it's fairly easy to invert the rings and end up in big trouble when you burn a qt of oil every 300 miles for no apparent reason. |
Lo-Fi Version | Time is now: 15th June 2024 - 08:04 PM |
