JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Here is a pic of my new restored rear Calipers. Huge tanks to Eric at PMB Performance (IMG:style_emoticons/default/pray.gif) . My calipers are beautiful. I still need to adjust them but will get to that tommorow night. The picture is a little dark but damn if my rotor doesn't look like crap with the new caliper there (IMG:style_emoticons/default/dry.gif)
I sent my short headers off to get Cermaic coated at a place in Portland. They will do one coat inside & 2 coats outside. I'm having them done in black as they said that had the best cooling. I'll get pics of these when I pick them up mid week. I also dropped off my muffler & pipes to get ceramic coated at another shop. It was a little cheaper than the place in Portland. The quality won't be as good either but that's okay for the muffler & pipes. I just did these to look nice really. It will help cooling also but not as much as my headers. Along with these I dropped off a bunch of heater parts to get powder coated for my LE. All the parts that connect to the heat exchangers. I took one full set along with all the spares I had. Made sense to just get them all done & looking nice. I'm excited as this guy is pretty cheap & does nice work. I guess I will reserve my judgement until I get all my parts back though. I will get pics up for this stuff this weekend when I pick them up. Attached image(s) ![]() |
matthepcat |
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California ![]() |
Is the smoke comming from the exhaust or engine compartment?
Are you using a distributor on this motor? (Is the distributor hold down clamp loose?)---check timing Any vacuum lines or ports come unplugged? Is your choke plate on your carb stuck closed? Oil from your dip-stick leak is probably collecting at the union between the engine and trans. |
Lo-Fi Version | Time is now: 1st August 2025 - 03:31 AM |
