Oil cooler how to check?, probably leaky oil cooler |
Jacco |
May 5 2004, 01:10 AM
Designated Dutchman Group: Members Posts: 194 Joined: 23-February 04 From: the Netherlands Member No.: 1,703 Region Association: Europe |
Hi,
Just a quistion for you. Our 914 was leaking large amounts of oil, I suspected the oil seals between cooler and block. Last weekend I had time to work on it so I pulled the engine and tore it down. But the seals seemed fine but the cooler was an oily mess. Luckily we had another block laying around with a known good cooler replaced it and the seals. But here's the question, can any (VW) carshop check an oilcooler for leaks Is this oil cooler the same as the later type 1 oil cooler? looks the same but type 1 unit is probably smaller, right? that's about it, need to get the car checked for admission on the road so I can (legally) drive it around again (IMG:style_emoticons/default/boldblue.gif) cheers, Jacco de Haan Delft, the Netherlands |
Mark Henry |
May 5 2004, 06:59 AM
Sometimes it's the oil pressure switch, which is just above the cooler. At it's worst this would be a drip every couple of seconds.
Another cause is if the cooler is way over-torqued it can bend the cooler, they can also crack but this is not a big problem. If the seals were just leaking a little they may still "look" in good shape, even though they were leaking. I've seen seals blow (on a type 1) from a stuck relief valve. This car had been sitting for years. A blown cooler seal dumps massive amounts of oil. It's the same cooler but it has 2 more rows. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:52 AM |
