> i have 96mm P&C's - where to measure for stroke?, are they 66 or 71 ??
jimkelly
post Dec 13 2011, 11:40 AM
Delaware USA
pic
bore and stroke chart - http://www.914world.com/specs/engnumbs.php
Valy
post Dec 13 2011, 12:51 PM
Actually, I believe you got the wrong answer.
The KB pistons that were discussed in other threads are made for longer rods.
The original pin height of the 2.0 is ~35mm from pin center to piston top.
It looks like the cylinders you have are for a 71mm stroke.
jcd914
post Dec 13 2011, 08:10 PM
QUOTE(Valy @ Dec 13 2011, 10:51 AM) *
I am going to disagree here.
Jim is measuring the same way as Mark Henry did in the previous thread and coming out the almost the same measurements as Mark did for the stock 1.7 & 1.8 pistons.
To me that says Jim has pistons with the pin set for 1.7/1.8 stroke.
In the other thread Mark measured from the piston top to the top of the pin bore (just like Jim is showing us) and had the following for stock pistons:
2.0, .933"
1.8, 1.178"
1.7, 1.184"
1.178" ~= 29.9mm for 1.8L
1.184" ~= 30.1mm for 1.7L
Jim is measuring approx 30mm which matches 1.7/1.8.
He should be closer to 26mm/27mm for 2.0L
Jim
- Lo-Fi Version Time is now: 15th April 2026 - 01:12 PM
