Oil cooler how to check?, probably leaky oil cooler |
Jacco |
May 5 2004, 01:10 AM
Designated Dutchman Group: Members Posts: 194 Joined: 23-February 04 From: the Netherlands Member No.: 1,703 Region Association: Europe |
Hi,
Just a quistion for you. Our 914 was leaking large amounts of oil, I suspected the oil seals between cooler and block. Last weekend I had time to work on it so I pulled the engine and tore it down. But the seals seemed fine but the cooler was an oily mess. Luckily we had another block laying around with a known good cooler replaced it and the seals. But here's the question, can any (VW) carshop check an oilcooler for leaks Is this oil cooler the same as the later type 1 oil cooler? looks the same but type 1 unit is probably smaller, right? that's about it, need to get the car checked for admission on the road so I can (legally) drive it around again (IMG:style_emoticons/default/boldblue.gif) cheers, Jacco de Haan Delft, the Netherlands |
TonyAKAVW |
May 5 2004, 11:33 AM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I had the same symptoms with my oil cooler. The switch was fine, the seals were good, it turned out that the cooler was bad. I took the cooler to a local machine shop and they did a pressure test and found leaks.
-Tony |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:58 AM |
