Tire sizes / Handling, Need a pros thoughts |
ruby914 |
Dec 17 2011, 02:50 AM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
I got a 911 front end and a set of 7 & 8 x 16'' 5 lug fuchs for my WRX914, not from the same car.
The Fuchs had a set of used tires that I have not yet replaced. The front tires 205/55 had heavy wear on the inside tread when I got them. The rears are 225/50 After doing an alignment I found the steering heavy and didn't center out from a turn. If do a tight U-turn, best I can explain it, it feels like the tires are buckling over them selves or washing out? I added a little more toe-in to help the centering but no change. My first question: Would that wear on the inside tread make the steering heavy and not straiten out? So, I need new tires. Here is my delima... On my other stock 914, I have 195/50 x 15 and really like the feel, very light, low and quick response with the smaller diameter tires. The WRX914 will be a daily driver. 1st, I wonder if new tires will correct all the current problem? 2nd question, I think of going a step lower profile to 225/45 and 205/45. Does this choice sound reasonable? But there is something else I feel I must consider. When the turbo kicks in, in 2nd gear ( 914 transaxle ) if I am pushing it on a curved freeway on-ramp or if the street is a little damp it breaks loose easy. So, I think of 245/45's in the rear and 205/50 up front. But that is not doing much in keeping the diameters lower. This is the tire size calculater I have used http://www.1010tires.com/TireSizeCalculato...p?action=submit Is there any option that I have missed? BTW I now have GT flares sheet metal screwed to my car marked for trim and welding. I have one uninstalled set of 21mm wheel spacers and I think I will need one more set, maybe the same offset. I think, I should get my new tires worked out before I look at the spacers again. |
ruby914 |
Dec 17 2011, 11:56 AM
About 8 months ago, I did the alignment myself.
I used the dimensions from the Haynes manual. I used 8'x 1" alum. channel, off the bead of the tire and marks on the ground, to set the toe. A level to set the to set the camber. I don't remember paying with the caster. I just took a look, the struts are all the way forward. I will pull it back and see if it makes a differences. The tires are old and used from PO 911, can't use the wear pattern for reference to my alignment. But, with a good alignment it would effect handling. Like too much camber I would think. The scrub radius is something I didn't know about. Good link, Thanks. To remove the garbage in garbage out effect, I think the more important question now is the new tire size? I just don't find a tire combo that I am completely happy with. |
J P Stein |
Dec 17 2011, 12:39 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Lo-Fi Version | Time is now: 7th June 2024 - 06:48 PM |
