| mxhondarider832 |
Nov 5 2009, 01:45 PM
Newbie ![]() Group: Members Posts: 1 Joined: 5-November 09 From: carlsbad,CA Member No.: 11,013 Region Association: None |
I have a '74 914 and the transmission is a little leaky and need to change the fluid, the book says to use straight 90w oil but I am having a really tough time finding it so I was wondering if there was a newer substitute that I could use. This is my first 914 and I am struggling a little bit and could use some help thanks
| SirAndy |
Nov 5 2009, 02:19 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,488 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Swepco 201 is expensive and the Cap'n will tell you it's no good but i've been running it for years with very good results.
It made a noticeable improvement in shifting from whatever the PO had used. Transmission oil is not really a "wear" item, which makes it easier to justify the extra expense for Swepco. I cleaned up and re-sealed my 901 about two years ago and it's still bone dry. (IMG:style_emoticons/default/stirthepot.gif) Andy PS: (IMG:style_emoticons/default/welcome.png) |
| Richard Casto |
Dec 19 2011, 09:58 AM
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
Transmission oil is not really a "wear" item, which makes it easier to justify the extra expense for Swepco. Yes and no. Transmission oil doesn't live as hard of a life as engine oil, but I would put it firmly in the "wear item" or "needs to be replaced" category. Stuff can get inside (such as via the breather vent) and periodic replacement can flush that stuff out. Also, the oils have additives (particular such as the EP - Extreme Pressure) that do not last indefinitely. Not that you said it, my concern is I don't want new owners to think transmission fluid is a "never change" item. It does have a service schedule. Redline oil is actually contraindicated in our gearboxes (hypoid gears). I know why you are saying this, can almost agree, but don't agree. Redline does have a GL-5 transmission fluid that should be fine in our transmission. I haven't used it, so I can't say how well it works. Even your other post above with the text from the Redline site does says which of their fluids to use in our transmission. What concerns me about Redline is that it's really easy to buy the wrong fluid from them. I see lots of comments about "Redline MT Fluid". Are they using "MT" as a generic term for "Manual Transmission" fluid or the specific "MT/MTL" product line from Redline? The specific "MT/MTL" line of fluids from Redline is GL-4 ("4" not "5") and should NOT be used in a 901/914 transmission. As you say above it is not GL-5 and is not compatible with hypoid designs. So we can agree on that. Specifically the following from Redline should NOT be used in a 901/914 * Red Line MT-90 GL-4 (Not GL-5 spec) * Red Line MT-80 GL-4 (Not GL-5 spec) * Red Line MTL GL-4 (Not GL-5 spec) But Redline does have two GL-5 products. BUT of their two GL-5 fluids, one has a lot of friction modifiers and even on their site says that it should NOT be used in transaxles (combo transmission with synchros and a differential). That due to the friction modifiers you may experience bad shift quality. In short that fluid should also NOT be used in a 901/914 transmission. The second one however does look to fit the bill. Basically you really have to read all of the fine print to zero in on that one single product out of a small sea of manual transmission fluids from them. That one Redline fluid that should work is "75W90 NS GL-5 Gear Oil". The three things to note are... * "75W90". The viscosity is not 80W90, but probably is fine * "NS". This is the version that has less friction modifiers so it is more compatible with our synchro design. * "GL-5". It is GL-5 spec and works with hypoid gears. Here is a direct link on thier site... http://www.redlineoil.com/product.aspx?pid=47&pcid=7 Now because it is so easy to buy the wrong thing from them I can understand the "Don't buy Redline" stance. Even then, someone may use the right stuff from them and still report problems (such as the other thread in which Swepco is not working well for one guy), or it might work great for them. As always, your mileage may vary! On top of all of that, I put Redline in the "boutique" category just like Swepco. Which again may or may not add any real value. I probably wouldn't buy it personally and would just buy good quality GL-5 dino oil from one of the regular mainstream vendors (Valvoline, Castrol, etc.). Lastly, here is my article on transmission fluid... http://www.blueskymotorsports.com/index.ph...16&Itemid=6 Richard |
mxhondarider832 Transmission Fluid Nov 5 2009, 01:45 PM
underthetire OH no, you just poked a pimple. I use 80/90 stand... Nov 5 2009, 01:54 PM
Drums66
That's what I use!........put whatever ... Nov 5 2009, 04:27 PM
Zundfolge I had a harder time finding the 17mm allen wrench ... Nov 5 2009, 02:18 PM
Randal
Swepco 201 is expensive and the Cap'n will te... May 27 2013, 02:01 PM
tat2dphreak I'm using Valvoline 85w-90 I think it's a ... Nov 5 2009, 02:54 PM
tod914 Just put the Swepco in mine. Shifts much better l... Nov 5 2009, 04:35 PM
Mark Henry Just use the cheap gear oil and change it once and... Nov 5 2009, 04:51 PM
westgl Redline MTL is the old gearoil dont use it
USE: R... Nov 7 2009, 12:50 AM
Drums66
USE: ... Nov 8 2009, 01:37 PM
ME733 :popcorn: ...bottom line is THIS If you have reall... Nov 7 2009, 04:53 PM
Dr Evil
:popcorn: ...bottom line is THIS If you have real... Nov 7 2009, 09:14 PM
detoxcowboy
:popcorn: ...bottom line is THIS If you have rea... Nov 7 2009, 10:18 PM
detoxcowboy make sure you get your fill plug off first before ... Nov 7 2009, 04:58 PM
Dr Evil From the redline website found here:
http://www.re... Nov 8 2009, 01:48 PM
Cap'n Krusty I don't recall EVER saying Swepco gear oil is ... Nov 8 2009, 02:58 PM
astronomerdave So, the people selling components to convert 914s ... Nov 9 2009, 01:11 AM
Drums66 Blah Blah Woof Woof..........I go by experience ,y... Nov 9 2009, 01:16 PM
astronomerdave
did you read my last post(20 years) same gear oi... Nov 9 2009, 01:32 PM
Dr Evil :WTF: is your problem? Nov 9 2009, 01:22 PM
underthetire Did you see my first post? First reply? I told you... Nov 9 2009, 01:38 PM
Dr Evil So you are saying that people are allowed to be je... Nov 9 2009, 01:57 PM
detoxcowboy :DRUNK: Nov 9 2009, 02:04 PM
Gint :WTF: is with you people lately? I feel like a ba... Nov 9 2009, 03:11 PM
:WTF: is with you people lately? I feel like a b... Nov 9 2009, 03:26 PM
underthetire Funny thing to, Redline MT90 is fairly new. It... Nov 9 2009, 03:44 PM
Drums66
Funny thing to, Redline MT90 is fairly new. It... Dec 20 2011, 05:00 PM
wobbletop When I visited the local Swepco guy, he showed me ... Nov 9 2009, 03:48 PM
Richard Casto
When I visited the local Swepco guy, he showed me... Dec 19 2011, 10:00 AM
steuspeed Dr. Evil. So I should be running this Red Line non... Dec 18 2011, 10:30 PM
gothspeed
Dr. Evil. So I should be running this Red Line no... Dec 19 2011, 03:05 PM
Dr Evil Use what you want. I already posted my experience ... Dec 19 2011, 06:34 PM
SirAndy Tranz oil is absolutely a wear item; Heat and dir... Dec 21 2011, 02:56 PM
Steve
Tranz oil is absolutely a wear item; Heat and di... Dec 21 2011, 06:19 PM
SirAndy I'm confused... if the oil doesn't get ho... Dec 21 2011, 06:23 PM
Steve
I'm confused... if the oil doesn't get h... Dec 21 2011, 06:28 PM
SirAndy It's funny why Porsche put external oil cooler... Dec 21 2011, 06:30 PM
Drums66
It's funny why Porsche put external oil coole... Dec 21 2011, 07:26 PM
Dr Evil
Tranz oil is absolutely a wear item; Heat and di... Dec 21 2011, 06:24 PM
Mark Henry Oil preference is almost as bad as politics and re... Dec 21 2011, 06:03 PM
Richard Casto Regarding heat... In another thread elsewhere it w... Dec 21 2011, 09:07 PM
Steve I need to toss some old oils in the garage, but I ... Dec 26 2011, 11:04 AM
steuspeed I'm going back to NON synthetic ASAP! I ca... Dec 26 2011, 02:06 PM
scott_in_nh I had shifting that was about the same as the OP... Dec 26 2011, 08:36 PM
steuspeed I could not find Valvoline without the Limited Sli... Dec 30 2011, 01:29 AM
442nd914s If I can just ask a simple question. And only beca... Dec 18 2012, 05:35 PM
steuspeed
If I can just ask a simple question. And only bec... Jan 2 2013, 04:23 PM
Dr Evil Hey Dude,
We all have to learn some time. You ar... Dec 18 2012, 06:55 PM
Dave_Darling Use approx 3L of 80w90 GL5 oil and fill until the ... Jun 25 2013, 06:31 PM
Dr Evil ALWAYS take the FILL plug out first. If you drain ... Jan 2 2013, 04:57 PM
mrbubblehead after finding out how much it costs for new gearbo... Jan 2 2013, 08:30 PM
Dr Evil
after finding out how much it costs for new gearb... Jan 3 2013, 05:00 PM
Steve73 <_< How about SuperTech 80w-90 GL-5 from...... May 27 2013, 01:52 PM
396 Like its been said...it's like religion. I... May 27 2013, 04:52 PM
d962r
Like its been said...it's like religion. I... Jun 25 2013, 05:41 PM
monkeyboy
Like its been said...it's like religion. I... Jun 26 2013, 12:10 PM
second wind
[quote name='d962r' post='1885135' date='Jun 25 2... Jan 4 2023, 02:29 AM
zoomCat
Ok....is it just me or is this thread REALLY CONF... Jan 4 2023, 11:39 AM
emerygt350
[quote name='d962r' post='1885135' date='Jun 25 ... Jan 4 2023, 11:58 AM
914043
[quote name='second wind' post='3049101' date='Ja... Jan 4 2023, 01:17 PM
Steve
[quote name='second wind' post='3049101' date='J... Jan 5 2023, 12:00 PM
Front yard mechanic Being a ten year old thread you might as well star... Jan 4 2023, 06:16 AM
second wind Here is a good question....will adding Lucas Oil S... Jan 6 2023, 01:16 PM
Superhawk996
Here is a good question....will adding Lucas Oil ... Jan 6 2023, 09:37 PM
Geezer914 Kendall MS-NP Hypoid gear oil 80-90W. Jan 6 2023, 05:25 PM
Brian Fuerbach
I have to ... Jan 6 2023, 09:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th July 2026 - 11:21 PM |
