Results from changing my tranny oil to SWEPCO 201, Comments on transmission oil. |
steuspeed |
Dec 18 2011, 07:20 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
So I have had my car about 6 months now. It has 105k on the clock. No record of when the last time the transmission oil was changed. First and second gear syncros are toast, but if I am real careful I can get it to slip in without grinding. Got to put it in first just before you come to a stop. I just changed the oil (Brad Penn) and thought it would be a good time to try some SWEPCO 201 in the transmission. The oil that drained out looked pretty good. Still had an amber color to it but a little on the low side. So now with the SWEPCO 3rd has a real notchy feel to it. second will zip on the teeth as I come down from third with my usual methods. First is even more finicky than before. Outside Temp is 35-45 degree range right now. Will this get better over time? Seems like I went backwards. (IMG:style_emoticons/default/sad.gif) Any comments welcome.
J P Stein |
Dec 21 2011, 08:54 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Manny's the time I reused the oil I had drained out.....after all. it's 50 bucks a gallon. (IMG:style_emoticons/default/biggrin.gif) , a trans is not an engine, and MY usage was at most 300 miles a season after I took it off the street....hard miles but... Contamination consisted of metallic particles stuck the the magnetic drain plug,
Over the years I ran the stuff I bought maybe 3 gallons of Swepco. I spent a hell of a lot more on engine oil......the best I could find.....I suppose that was an error also? You do your thing, Doc, I did mine......that meant taking care of my equipment as best I could which worked out pretty damn well. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:48 AM |
