| McMark |
Dec 21 2011, 08:58 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Tomorrow I start cutting metal and building the rotisserie I should have had a long time ago. I'm actually quite eager to get going on this project, more than I anticipated. Not only because I've wanted a rotisserie for a long time, but also because once it's finished the 914 that's sitting on the Celette bench will go on the rotisserie. Then I can put a 66 912 project up on the bench and start building my first set of Celette fixtures. Even though they'll be for a 912, the techniques I learn will make the 914 fixtures even better.
I'll be posting pictures of my progress tomorrow, but I couldn't wait to share. (IMG:style_emoticons/default/boldblue.gif) |
| Elliot Cannon |
Dec 22 2011, 12:31 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
So it basically acts as kind of a factory jig?
McMark Building a Rotisserie Dec 21 2011, 08:58 PM
kg6dxn COOL! :Qarl: Dec 21 2011, 09:00 PM
strawman There is no way I could have stripped, repaired an... Dec 21 2011, 11:46 PM
Elliot Cannon
Tomorrow I start cutting metal and building the r... Dec 22 2011, 12:20 AM
McMark The actual Celette bench is just a big-ass cart. ... Dec 22 2011, 12:28 AM
Elliot Cannon Here he is ladies and gentlemen. The man his own... Dec 22 2011, 12:33 AM
McMark
That's totally right. It's mentioned by ... Dec 22 2011, 12:51 AM
RobW :trophy: :trophy: :trophy: :trophy: :trophy: ... Dec 22 2011, 07:42 AM
FourBlades Just make sure you buy enough 2x4s before you star... Dec 22 2011, 02:11 PM
KELTY360
Just make sure you buy enough 2x4s before you sta... Dec 22 2011, 06:22 PM
URY914 My advice is to use at least 5" steel caster ... Dec 22 2011, 04:07 PM
URY914
My advice is to use at least 5" steel caster... Dec 23 2011, 08:28 PM
aircooledtechguy
[quote name='URY914' post='1593389' date='Dec 22 ... Dec 24 2011, 09:54 AM
cary
My advice is to use at least 5" steel caster... Dec 10 2012, 10:40 PM
9fourteen This may be a dumb question but how do you get the... Dec 22 2011, 06:29 PM
jcd914
This may be a dumb question but how do you get th... Dec 22 2011, 06:58 PM
okieflyr
This may be a dumb question but how do you get t... Dec 22 2011, 07:46 PM
bigkensteele
This may be a dumb question but how do you get th... Dec 22 2011, 07:07 PM
KELTY360
This may be a dumb question but how do you get t... Dec 22 2011, 07:28 PM
FourBlades To get it on the rotisserie, just borrow a set of ... Dec 22 2011, 07:26 PM
McMark :agree: Lifting it manually is a great option. Al... Dec 22 2011, 11:55 PM
leebenedi Just one question. I plan on putting my 914 on a r... Dec 23 2011, 03:25 AM
9fourteen
Just one question. I plan on putting my 914 on a ... Dec 23 2011, 07:53 AM
leebenedi Thank you for the responses. My rust is not as bad... Dec 24 2011, 01:55 AM
Thank you for the responses. My rust is not as ba... Dec 24 2011, 10:39 AM
scotty b I know the bumper holes are the standard mounting ... Dec 23 2011, 08:00 AM
scotty b Put the jack on the inside. Placing it on the outs... Dec 23 2011, 08:02 AM
scotty b this Dec 23 2011, 08:07 AM
McMark :agree: Lee, you should fix the bumper mounts FIRS... Dec 23 2011, 11:04 AM
scotty b
:agree: Lee, you should fix the bumper mounts FIR... Dec 23 2011, 05:22 PM
strawman To get the body on the rotisserie, you should stri... Dec 23 2011, 11:35 AM
McMark Goeff, adding a ring to the top of your body cross... Dec 23 2011, 02:44 PM
McMark Got the wheels and the center legs completed. Now... Dec 23 2011, 04:14 PM
strawman http://www.914world.com/bbs2/uploads/post-419-1324... Dec 24 2011, 01:25 AM
Elliot Cannon Are those casters big enough? Dec 23 2011, 07:54 PM
9fourteen I am curious as to why you put the casters on the ... Dec 23 2011, 08:35 PM
McMark Casters were from another project. If they die, I... Dec 23 2011, 10:12 PM
RobW
What... Li... Dec 24 2011, 01:09 AM
shuie I welded angle iron on the end of the square tube ... Dec 24 2011, 11:58 AM
jimkelly looks good.
the caster brackets look like ankle b... Dec 24 2011, 06:39 AM
McMark Finally found the bearing setup I wanted to make t... Jan 25 2012, 05:36 PM
ConeDodger
Finally found the bearing setup I wanted to make ... Mar 10 2012, 09:20 PM
scotty b :thumbsup: I thought aboot using rear bearing... Jan 25 2012, 05:41 PM
burton73 Mark,
This is on my unit I bought it for $11... Jan 25 2012, 06:04 PM
McMark I'm building a similar locking pin setup.
The... Jan 25 2012, 06:19 PM
mr914 I built my rotiserie a number of years ago.
I use... Mar 10 2012, 06:49 PM
mr914 Built it so I could break it down and store it.
S... Mar 10 2012, 07:05 PM
sixnotfour
No... But the steering wheel Is.. :lol: :rotfl: Mar 10 2012, 09:50 PM
McMark Finally finished up the brackets for the rotisseri... Jun 25 2012, 08:29 PM
FourBlades Looks great! That is very innovative.
Now ju... Jun 25 2012, 08:45 PM
jsconst I happen to be there when they were rolling it out... Jun 25 2012, 08:54 PM
scotty b Hey Mark I've got to build another for a 911 I... Jun 26 2012, 06:13 PM
McMark It's balanced enough to handle by myself. I h... Jun 26 2012, 10:53 PM
McMark Time to build 914 fixtures since my restoration pr... Dec 10 2012, 08:01 PM
Socalandy Did I miss it or did everyone pass on saying...
I... Dec 10 2012, 08:09 PM
McMark Just finished up the rear bar. Tomorrow it goes u... Dec 10 2012, 09:42 PM
SirAndy Can't wait to put this to "good" use... Dec 10 2012, 10:14 PM
bigkensteele
Can't wait to put this to "good" us... Dec 12 2012, 08:15 PM
914Eric Nice!
:popcorn: Dec 10 2012, 10:21 PM
McMark I'm going to try out the methods described in ... Dec 11 2012, 10:26 AM
Gint Love the steering wheel! Dec 11 2012, 11:50 AM
McMark 914 fixtures complete! :boing:
Spent a lot... Dec 12 2012, 08:10 PM
McMark Yes. :evilgrin: Dec 12 2012, 08:17 PM
KELTY360 Paint it yellow...the work will go faster! Dec 13 2012, 12:47 AM
jaxdream What type of chassis leaning against the wall in t... Dec 13 2012, 10:50 AM
McMark Type3 VW chassis. We welded new pans on it. Dec 13 2012, 10:54 AM
jaxdream Ahh , thought so , but wasn't 100% sure . VW w... Dec 13 2012, 11:05 AM
FourBlades 914 Limo on the rotisserie!!! :popcor... Dec 13 2012, 11:14 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 08:01 AM |
